ArrayArrayArray BrainModular BrainModular Users Forum 2006-12-09T22:48:59+01:00 https://brainmodular.org/forums/app.php/feed/topic/187 2006-12-09T22:48:59+01:00 2006-12-09T22:48:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=187&p=855#p855 <![CDATA[some little suggestions ...]]>
you mean replace the message
'do you really want to open worksapce?'
by
'save the actual workspace?' then save the old patch and load the new?
yes, something like that or " the current workspace has been modified
do you want to save changes , yes , no ,cancel...
but the problem is that i don't have any message when i try to open a workspace ( ctrl O ) or by the menu
( working with free version 2.5 )
Statistics: Posted by nay-seven — 09 Dec 2006, 22:48
2006-12-09T22:20:38+01:00 2006-12-09T22:20:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=187&p=853#p853 <![CDATA[some little suggestions ...]]>
1_for the conductor window , would be cool to swap between lite and normal "on" the window itself
yes, yes, yes
2_when you open a new workspace ,could be cool to have a " save before closing " for stupid boy like me..;-)
by
3_a way to insert a patch in a patch , for exemple insert a "envellope follower " patch in a sampler patch....
It's possible: just drag and drop a new patch in the main one while pressing the 'ctrl key'. we call it sub patch. You can create sub-patch in sub-patch in sub- patch and so on. They is no limitation...
Statistics: Posted by senso — 09 Dec 2006, 22:20
2006-12-09T22:00:09+01:00 2006-12-09T22:00:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=187&p=850#p850 <![CDATA[some little suggestions ...]]> i've assign 2 notes on my keyboard , previous and next of course but time to time , it's better to switch to normal mode
and a mouse click would be faster ( for me ) than a ctrl F7
3_a way to insert a patch in a patch , for exemple insert a "envellope follower " patch in a sampler patch....( edit : ok i've found the ctrl+library options...great ! )
ok , i stop here :)
Statistics: Posted by nay-seven — 09 Dec 2006, 22:00
by
yes, yes, yes
by
ok , i stop here :)
