ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-03-23T15:23:22+01:00 https://brainmodular.org/forums/app.php/feed/topic/1856 2010-03-23T15:23:22+01:00 2010-03-23T15:23:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=1856&p=12856#p12856 <![CDATA[PCHAR question]]> Statistics: Posted by anbd — 23 Mar 2010, 15:23
2010-02-06T13:04:02+01:00 2010-02-06T13:04:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=1856&p=11453#p11453 <![CDATA[PCHAR question]]> Thanks!
Statistics: Posted by Gizzeta — 06 Feb 2010, 13:04
2010-01-20T15:51:21+01:00 2010-01-20T15:51:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=1856&p=11259#p11259 <![CDATA[PCHAR question]]>
in yourmodule.h
add includes
CODE:
#include <string>#include <vector>
and a vector in your module class
CODE:
class TYourModule &#58; public TUserModule&#123;    ...    std&#58;&#58;vector<std&#58;&#58;string> m_vectOutCaptions;    ...&#125;
in yourmodule.cpp
add includes and namespace use
CODE:
#include <string>#include <sstream>#include <vector>using namespace std;
and in GetParamInfo()
CODE:
void GetParamInfo &#40;void* pModule,int n, TParamInfo* pParamInfo&#41;&#123;    // make convenient pointer to the module    TYourModule* pYourModule = &#40;&#40;TYourModule*&#41;pModule&#41;;            // the param name    stringstream Stream;     Stream << &#40;n + 1&#41;;    pYourModule ->m_vectOutCaptions.push_back&#40;string&#40;"Out "&#41; + Stream.str&#40;&#41;&#41;;    if&#40;n < NUM_OF_OUT&#41;    &#123;                pParamInfo->ParamType   = ptArray;        pParamInfo->Caption     = &#40;PCHAR&#41;&#40;pYourModule ->m_vectOutCaptions&#91;n&#93;.c_str&#40;&#41;&#41;;        pParamInfo->IsInput     = false;        pParamInfo->IsOutput    = true;    &#125;&#125;
Statistics: Posted by martignasse — 20 Jan 2010, 15:51
2010-01-20T13:25:01+01:00 2010-01-20T13:25:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1856&p=11258#p11258 <![CDATA[PCHAR question]]>
PCHAR is a plain old pointer to char (char*)
so you can do something like this :
in your module class member definition
CODE:
PCHAR OutNames&#91;NUM_OF_OUT&#93;;
in your module constructor
CODE:
for &#40;int n=0;  n < NUM_OF_OUT; n++&#41;&#123;     OutNames&#91;n&#93; = new char&#91;STRING_BUFF_SIZE&#93;;    sprintf_s&#40; OutNames&#91;n&#93;, STRING_BUFF_SIZE, "Out%i", &#40;n +1&#41;&#41;;&#125;
in GetParamInfo
CODE:
void GetParamInfo &#40;void* pModule,int n, TParamInfo* pParamInfo&#41;&#123;if&#40;n < NUM_OF_OUT&#41;&#123;                pParamInfo->ParamType   = ptArray;        pParamInfo->Caption     = &#40;&#40;YourModule*&#41;pModule&#41;->OutNames&#91;n&#93;;        pParamInfo->IsInput     = false;        pParamInfo->IsOutput    = true;&#125;&#125;
in your module destructor
CODE:
for &#40;int n=0;  n < NUM_OF_OUT; n++&#41;&#123;            if &#40;OutNames&#91;n&#93; != NULL&#41;    &#123;        delete&#91;&#93; OutNames&#91;n&#93;;    &#125;&#125;
not tested, but it should do the trick
Statistics: Posted by martignasse — 20 Jan 2010, 13:25
2010-01-20T00:59:56+01:00 2010-01-20T00:59:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=1856&p=11255#p11255 <![CDATA[PCHAR question]]> I would like to do an object whit N out.
To do this I define the number of output in the .h like this
CODE:
#define NUM_OF_OUT 24
then I allocate an array of TEVT*
CODE:
TEVT*pOut&#91;NUM_OF_OUT&#93;;
in the .cpp I write
CODE:
void GetParamInfo &#40;void* pModule,int n, TParamInfo* pParamInfo&#41; &#123;if&#40;n < NUM_OF_OUT&#41;&#123;pParamInfo->ParamType= ptArray;pParamInfo->Caption= "Out";pParamInfo->IsInput= false;pParamInfo->IsOutput= true;&#125;
and
CODE:
void SetEventAddress &#40;void* pModule, int n, TEVT* pEvent&#41; &#123;TMyModule* pMyModule = &#40;&#40;TMyModule*&#41;pModule&#41;;if&#40;n < NUM_OF_OUT&#41;&#123;pMyModule->pOut&#91;n&#93;   = pEvent;&#125;
it works, no problem.
Now I would like to change the Caption of each out like this: Out1, Out2, ..., Out24.
How can I do it?
pParamInfo->Caption is a PCHAR type, how can I manipulate a string like this?
Thanks for help
Statistics: Posted by Gizzeta — 20 Jan 2010, 00:59
in yourmodule.h
add includes
CODE:
CODE:
in yourmodule.cpp
CODE:
CODE:
CODE:
CODE:
in GetParamInfo
CODE:
CODE:
CODE:
CODE:
in the .cpp I write
CODE:
and
CODE:
How can I do it?
Thanks for help
