ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-01-02T11:37:47+01:00 https://brainmodular.org/forums/app.php/feed/topic/1843 2010-01-02T11:37:47+01:00 2010-01-02T11:37:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=1843&p=11148#p11148 <![CDATA[Randomize step help]]>
One of the key in usine patching is to separate data manipulation and data visualisation, it's often necessary ;)
I will keep that in mind. I have not thought of that before.
thanks again to you all for your efforts.
Statistics: Posted by soundmind — 02 Jan 2010, 11:37
2010-01-02T11:09:31+01:00 2010-01-02T11:09:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=1843&p=11146#p11146 <![CDATA[Randomize step help]]>
Its very simple the problem is it only randomizes the steps that are currently visible (no of steps). I want to randomize the entire array no matter what number the no of steps is on. i want it to randomize the steps beyond the currently selected no of steps.
Ok, i see the problem.
When you click the random button, the array size of the second step is exactly what decided by the first step, no more.
So you have to make real what you call implicitly 'the entire array', and randomize that.
Hope it help.
Statistics: Posted by martignasse — 02 Jan 2010, 11:09
2010-01-02T10:57:46+01:00 2010-01-02T10:57:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=1843&p=11145#p11145 <![CDATA[Randomize step help]]> Image
Statistics: Posted by nay-seven — 02 Jan 2010, 10:57
2010-01-02T10:33:45+01:00 2010-01-02T10:33:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=1843&p=11144#p11144 <![CDATA[Randomize step help]]> Image
Statistics: Posted by amiga909 — 02 Jan 2010, 10:33
2010-01-02T01:14:02+01:00 2010-01-02T01:14:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=1843&p=11143#p11143 <![CDATA[Randomize step help]]> Image
It works fine but the only problem i am having is the randomization. Thanks for the help.
Statistics: Posted by soundmind — 02 Jan 2010, 01:14
2010-01-01T21:54:57+01:00 2010-01-01T21:54:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=1843&p=11142#p11142 <![CDATA[Randomize step help]]> Image
Statistics: Posted by nay-seven — 01 Jan 2010, 21:54
2010-01-01T21:48:39+01:00 2010-01-01T21:48:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=1843&p=11141#p11141 <![CDATA[Randomize step help]]> cause they're many way to do this kind of patch..
Statistics: Posted by nay-seven — 01 Jan 2010, 21:48
2010-01-01T21:23:57+01:00 2010-01-01T21:23:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=1843&p=11140#p11140 <![CDATA[Randomize step help]]>
Why do you need two step module ?
This should do the trick ?
or maybe i missunderstood...
Statistics: Posted by martignasse — 01 Jan 2010, 21:23
2010-01-01T20:20:17+01:00 2010-01-01T20:20:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=1843&p=11139#p11139 <![CDATA[Randomize step help]]> Statistics: Posted by soundmind — 01 Jan 2010, 20:20
Hope it help.
