it's not a matter of the missing '/' but more because no data is sent. Will be corrected in the V5. With the receive bytes module you can check if its length is 2 : it means that the message is like '/x'. Just a direction.
thanks for the info - very interesting...
Statistics: Posted by Clearscreen — 22 Dec 2009, 01:05
]]>2009-12-18T17:09:55+01:002009-12-18T17:09:55+01:00https://brainmodular.org/forums/viewtopic.php?t=1820&p=10974#p10974Statistics: Posted by grego mondo — 18 Dec 2009, 17:09
2009-12-18T13:02:52+01:002009-12-18T13:02:52+01:00https://brainmodular.org/forums/viewtopic.php?t=1820&p=10973#p10973Will be corrected in the V5. With the receive bytes module you can check if its length is 2 : it means that the message is like '/x'. Just a direction.
]]>2009-12-18T11:47:21+01:002009-12-18T11:47:21+01:00https://brainmodular.org/forums/viewtopic.php?t=1820&p=10972#p10972Statistics: Posted by Clearscreen — 18 Dec 2009, 11:47
]]>2009-12-17T21:45:05+01:002009-12-17T21:45:05+01:00https://brainmodular.org/forums/viewtopic.php?t=1820&p=10971#p10971Actually you're right it's not interpreted by Usine. I'll try to change this behavior but probably only in the V5. I hope you can wait...
]]>2009-12-17T03:39:49+01:002009-12-17T03:39:49+01:00https://brainmodular.org/forums/viewtopic.php?t=1820&p=10970#p10970 I couldn't get Usine's OSC receiver module to even detect any incoming message on the "/1" address unfortunately so not sure what to tell you Maybe Senso can help us out here?
Statistics: Posted by Clearscreen — 17 Dec 2009, 03:39
]]>2009-12-16T11:21:53+01:002009-12-16T11:21:53+01:00https://brainmodular.org/forums/viewtopic.php?t=1820&p=10965#p10965 sorry I wasn't clear enought :
I'm ok getting messages like : /1/fader 1/ (f) my problem is to get just a page change, message like /1/ ( ) I can see the title but it seems to send an empty message without any value ...
I can make a toggle with no other fonction than saying "I'm on the first page" or filter all the messages from /1/ but I'd like to find a way to send the actual page I'm on even if I didn't changed anything on it yet ...
hope it's clearer
thanks
Statistics: Posted by grego mondo — 16 Dec 2009, 11:21
good editor for pages but is there a way to make more than 4 pages on a layout ?
I'm using a 3Gs so and I've only just started with touchOSC so I'm not sure that all this applies, but if you right click on the page tabs in the editor you get a context menu saying "add page". I've had up to 10 pages at once.
Everything goes ok for messages wich I named in the TouchOSC editor but I would like to receive the name of the pages (e.g. : /1 ) but it only send a message like /1 (wich I see in the console) with no value ... !!
On mine everything on page 1 is received under /1/ in the OSC monitor, everything on page 2 comes as /2/ etc. For example using the 'simple' layout the left yellow fader on page 1 comes in as /1/fader1, the second left yellow as /1/fader2. On Page 2 the bottom left toggle button comes in as /2/toggle1 and so on...
You need to insert OSC inputs into a patch and set them to receive from the correct (eg/1/fader1) and then the values are output from the OSC modules data outputs.
I hope that helps - I know OSC can be confusing...
Statistics: Posted by Clearscreen — 16 Dec 2009, 03:52
]]>2009-12-15T19:11:48+01:002009-12-15T19:11:48+01:00https://brainmodular.org/forums/viewtopic.php?t=1820&p=10956#p10956 I use an IpodTouch wih TouchOSC (good editor for pages but is there a way to make more than 4 pages on a layout ?) Everything goes ok for messages wich I named in the TouchOSC editor but I would like to receive the name of the pages (e.g. : /1 ) but it only send a message like /1 (wich I see in the console) with no value ... !! so I can't get the pages change ( my purpose is like when I go o this page Usine bypass Line 1,2 & 3 in the rack mode of the fourth track)
Hope it's clear enought and sorry for my poor english ...
Statistics: Posted by grego mondo — 15 Dec 2009, 19:11
]]>2009-12-18T13:02:52+01:002009-12-18T13:02:52+01:00https://brainmodular.org/forums/viewtopic.php?t=1820&p=10973#p10973Will be corrected in the V5. With the receive bytes module you can check if its length is 2 : it means that the message is like '/x'. Just a direction.
hope it's clearer
thanks
