ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-11-27T20:16:01+02:00 https://brainmodular.org/forums/app.php/feed/topic/1786 2009-11-27T20:16:01+02:00 2009-11-27T20:16:01+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10784#p10784 <![CDATA[Wich template would you like to be added?]]> Statistics: Posted by ethnix73 — 27 Nov 2009, 19:16
2009-11-27T10:01:10+02:00 2009-11-27T10:01:10+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10782#p10782 <![CDATA[Wich template would you like to be added?]]> - for any audio out: mixer (N in ->1)
- for any outlet: trace value
also it could be nice if different module types were grouped (if easily possible). for example param inlets
LFO
step
data inlet
get from bus
user cruve sequencer
cancel
Statistics: Posted by amiga909 — 27 Nov 2009, 09:01
2009-11-26T21:55:39+02:00 2009-11-26T21:55:39+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10775#p10775 <![CDATA[Wich template would you like to be added?]]> Statistics: Posted by 23fx23 — 26 Nov 2009, 20:55
2009-11-26T21:53:33+02:00 2009-11-26T21:53:33+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10774#p10774 <![CDATA[Wich template would you like to be added?]]> Statistics: Posted by ethnix73 — 26 Nov 2009, 20:53
2009-11-26T21:52:42+02:00 2009-11-26T21:52:42+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10773#p10773 <![CDATA[Wich template would you like to be added?]]> Statistics: Posted by ethnix73 — 26 Nov 2009, 20:52
2009-11-26T21:21:17+02:00 2009-11-26T21:21:17+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10771#p10771 <![CDATA[Wich template would you like to be added?]]> Statistics: Posted by 23fx23 — 26 Nov 2009, 20:21
2009-11-26T09:37:16+02:00 2009-11-26T09:37:16+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10761#p10761 <![CDATA[Wich template would you like to be added?]]> Statistics: Posted by woodslanding — 26 Nov 2009, 08:37
2009-11-20T19:37:49+02:00 2009-11-20T19:37:49+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10700#p10700 <![CDATA[Wich template would you like to be added?]]>
Your idea is more about adding more function to the IML...interesting but not my point here. I can only create new templates with the existing IML
Statistics: Posted by ethnix73 — 20 Nov 2009, 18:37
2009-11-20T15:09:24+02:00 2009-11-20T15:09:24+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10696#p10696 <![CDATA[Wich template would you like to be added?]]> this wouldnt generate new module(s). instead the selected module is replaced by an equivalent module.
for example: module round
CODE:
faderoscillopscopedata outletsend to bus----------------cancel---------------replace with -> trunc&#40;x&#41;                      abs&#40;x&#41;                      1/X                      exp&#40;x&#41;
loads of questions come to mind:
which replace-with proposals should be there (everything with same inlet/outlet structure, only from same module sub-tree)?
which replacements are really needed?
the most often i replace modules is when i try different vst-plugins. automatic replacing with re-wiring would require scanning the vst-directory, handling different inlet/outlet structures, etc.!
...not sure if its a good idea!
Statistics: Posted by amiga909 — 20 Nov 2009, 14:09
2009-11-20T13:16:52+02:00 2009-11-20T13:16:52+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10694#p10694 <![CDATA[Wich template would you like to be added?]]>
I will have a look to see wich terminal does not have bus send and receive templates, and add them.
Statistics: Posted by ethnix73 — 20 Nov 2009, 12:16
2009-11-20T05:01:39+02:00 2009-11-20T05:01:39+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10688#p10688 <![CDATA[Wich template would you like to be added?]]>
The one thing would be buss send and receive for everything. But I think most terminals already have that.
Statistics: Posted by woodslanding — 20 Nov 2009, 04:01
2009-11-19T19:01:38+02:00 2009-11-19T19:01:38+02:00 https://brainmodular.org/forums/viewtopic.php?t=1786&p=10685#p10685 <![CDATA[Wich template would you like to be added?]]>
To be the most helpful with the communty, could tell me wich template would you like to be added?
Statistics: Posted by ethnix73 — 19 Nov 2009, 18:01
LFO
step
data inlet
get from bus
cancel
CODE:
