ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-11-20T03:58:10+01:00 https://brainmodular.org/forums/app.php/feed/topic/1784 2009-11-20T03:58:10+01:00 2009-11-20T03:58:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=1784&p=10687#p10687 <![CDATA[context for text outs and ins]]>
But is there a way to find the titles of the ins and outs of a module? Besides looking for a reference in another template? I got all the module numbers from the wiki....
Thanks!
Statistics: Posted by woodslanding — 20 Nov 2009, 03:58
2009-11-19T12:21:17+01:00 2009-11-19T12:21:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=1784&p=10684#p10684 <![CDATA[context for text outs and ins]]>
CODE:
Send Bus*   // file name ext &#40;'wav', 'usr', etc...&#41;2  // none=0,in=1,out=27   // term flowtype &#40;ftNone=0,ftPCM=1,ftInternText=2,ftData=3,ftMIDI=4,ftArray=5,ftUser=6,ftEvtText=7,ftPointer=8,ftIntern=9,ftOther=maxInt&#41;0 12 // term display flow type &#40;dftText=0,dftgain=1,dftDir=2,dftSwitch=3,dftButton=4,dFtInt=5,dftFloat=6,dftColor=7,dftListBox=8,dftArray=9,dftIpAddress=10,dftSmpte=11,dftFileName=12,dftMidiNote=13&#41;*   // termainal name can be '*' or "any string"SET_TARGET_PATCH SENDER_PATCHCREATE_MODULE bus1 113 MOUSE_X MOUSE_YCREATE_LINK SRC_MODULE SRC_TERM_NUM bus1 "NO NAME"SET_STRING_VALUE bus1 name SRC_VALUE_STRINGRENAME_MODULE bus1
The "Get Bus" module ID is 114, and the template is:
CODE:
Get Bus*   // file name ext &#40;'wav', 'usr', etc...&#41;1  // none=0,in=1,out=27   // term flowtype &#40;ftNone=0,ftPCM=1,ftInternText=2,ftData=3,ftMIDI=4,ftArray=5,ftUser=6,ftEvtText=7,ftPointer=8,ftIntern=9,ftOther=maxInt&#41;0 12 // term display flow type &#40;dftText=0,dftgain=1,dftDir=2,dftSwitch=3,dftButton=4,dFtInt=5,dftFloat=6,dftColor=7,dftListBox=8,dftArray=9,dftIpAddress=10,dftSmpte=11,dftFileName=12,dftMidiNote=13&#41;*   // termainal name can be '*' or "any string"SET_TARGET_PATCH SENDER_PATCHCREATE_MODULE bus1 114 MOUSE_X MOUSE_YCREATE_LINK bus1 "get bus" SRC_MODULE SRC_TERM_NUMSET_STRING_VALUE bus1 name SRC_VALUE_STRINGRENAME_MODULE bus1
Statistics: Posted by ethnix73 — 19 Nov 2009, 12:21
2009-11-19T04:54:10+01:00 2009-11-19T04:54:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=1784&p=10682#p10682 <![CDATA[context for text outs and ins]]>
IN and OUT do not work.
Here's templates for the data in and out if anybody wants them. These seem to work fine.
FILE: templatesdefaulttextIn02-DataIn.txt
CODE:
Data in *   // file name ext &#40;'wav', 'usr', etc...&#41;1   // none=0,in=1,out=27   // term flowtype &#40;ftNone=0,ftPCM=1,ftInternText=2,ftData=3,ftMIDI=4,ftArray=5,ftUser=6,ftEvtText=7,ftPointer=8,ftIntern=9,ftOther=maxInt&#41;0 12 // term display flow type &#40;dftText=0,dftgain=1,dftDir=2,dftSwitch=3,dftButton=4,dFtInt=5,dftFloat=6,dftColor=7,dftListBox=8,dftArray=9,dftIpAddress=10,dftSmpte=11,dftFileName=12,dftMidiNote=13&#41;*   // termainal name can be '*' or "any string"SET_TARGET_PATCH SENDER_PATCHCREATE_MODULE data1 20 MOUSE_X MOUSE_YCREATE_LINK data1 in SRC_MODULE SRC_TERM_NUM SET_STRING_VALUE data1 caption SRC_TERM_NAMERENAME_MODULE data1
FILE: templatesdefaulttextOut02-DataOut.txt
CODE:
Data out*   // file name ext &#40;'wav', 'usr', etc...&#41;2  // none=0,in=1,out=27   // term flowtype &#40;ftNone=0,ftPCM=1,ftInternText=2,ftData=3,ftMIDI=4,ftArray=5,ftUser=6,ftEvtText=7,ftPointer=8,ftIntern=9,ftOther=maxInt&#41;0 12 // term display flow type &#40;dftText=0,dftgain=1,dftDir=2,dftSwitch=3,dftButton=4,dFtInt=5,dftFloat=6,dftColor=7,dftListBox=8,dftArray=9,dftIpAddress=10,dftSmpte=11,dftFileName=12,dftMidiNote=13&#41;*   // termainal name can be '*' or "any string"SET_TARGET_PATCH SENDER_PATCHCREATE_MODULE data1 21 MOUSE_X MOUSE_YCREATE_LINK SRC_MODULE SRC_TERM_NUM data1 outSET_STRING_VALUE data1 caption SRC_TERM_NAMERENAME_MODULE data1
Statistics: Posted by woodslanding — 19 Nov 2009, 04:54
2009-11-18T02:23:06+01:00 2009-11-18T02:23:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=1784&p=10671#p10671 <![CDATA[context for text outs and ins]]>
-eric
Statistics: Posted by woodslanding — 18 Nov 2009, 02:23
2009-11-18T00:32:55+01:00 2009-11-18T00:32:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=1784&p=10670#p10670 <![CDATA[context for text outs and ins]]>
Data inlet
* // file name ext ('wav', 'usr', etc...)
7 // term flowtype (ftNone=0,ftPCM=1,ftInternText=2,ftData=3,ftMIDI=4,ftArray=5,ftUser=6,ftEvtText=7,ftPointer=8,ftIntern=9,ftOther=maxInt)
0 12 // term display flow type (dftText=0,dftgain=1,dftDir=2,dftSwitch=3,dftButton=4,dFtInt=5,dftFloat=6,dftColor=7,dftListBox=8,dftArray=9,dftIpAddress=10,dftSmpte=11,dftFileName=12,dftMidiNote=13)
RENAME_MODULE data1
Save it accordingly to the existing templates. For exemple "textout03-dataIn", if you have yet two templates for "textout"....
I don't know if you can create a template to load directly a vst, but you can load a patch with templates. Templates use the Internal Message Langage (p222 in the manual).
Statistics: Posted by ethnix73 — 18 Nov 2009, 00:32
2009-11-17T23:34:13+01:00 2009-11-17T23:34:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=1784&p=10669#p10669 <![CDATA[context for text outs and ins]]>
It would be nice to have data in and out, and buss send and receive options.
Is there a way to do this just by editing the templates?? I'm still trying to figure out how they work.
I'd love to change the template for opening a vst.....
Statistics: Posted by woodslanding — 17 Nov 2009, 23:34
Thanks!
CODE:
CODE:
CODE:
CODE:
-eric
Data inlet
RENAME_MODULE data1
