ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-11-16T17:40:42+01:00 https://brainmodular.org/forums/app.php/feed/topic/1780 2009-11-16T17:40:42+01:00 2009-11-16T17:40:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=1780&p=10647#p10647 <![CDATA[I need a midi scrip]]>
Thanks , I will try to do a patch with using a Mapper Value and a Create Midi patched before the receiving VST, like you said.
Franck et ses amis
Statistics: Posted by franck — 16 Nov 2009, 17:40
2009-11-16T15:58:03+01:00 2009-11-16T15:58:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=1780&p=10646#p10646 <![CDATA[I need a midi scrip]]>
Come to think of: Some velocity compression or expanding might also come in handy as well if the new VSTi reacts differently to that(?).
Statistics: Posted by bsork — 16 Nov 2009, 15:58
2009-11-16T15:36:37+01:00 2009-11-16T15:36:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=1780&p=10645#p10645 <![CDATA[I need a midi scrip]]>
Thanks for answer, I have see your patch MIDI mapper under libraryother , but I dont understand how is possible to change separete note on and note off. I see + or - 36 but where I can choose each notes ?
franck et ses amis
Statistics: Posted by franck — 16 Nov 2009, 15:36
2009-11-16T15:27:21+01:00 2009-11-16T15:27:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=1780&p=10644#p10644 <![CDATA[I need a midi scrip]]>
However, if you can live with an "unpacked" midi stream (ie only one message per execution block), I think you'd be better off using a Mapper Value and a Create Midi patched before the receiving VST.
Statistics: Posted by bsork — 16 Nov 2009, 15:27
2009-11-16T14:34:06+01:00 2009-11-16T14:34:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=1780&p=10642#p10642 <![CDATA[I need a midi scrip]]>
I change my VSTI drummer and the mapping is not the same than my new VSTI Drummer.
I search a script to convert several messages midi note on and note off with new message note on and note off (transpose).
I must to change 30 note on and note off with 30 new note on note off.
I have a lot of wkp with my old VSTI drummer and it is too long to changes all notes in piano roll.
I can do that with patch but I think it is more easy with script, but dont know script in usine, I know jus basic and assembly code..
Thanks for your help.
Franck et ses amis
sorry with my poor english
Statistics: Posted by franck — 16 Nov 2009, 14:34
Franck et ses amis
franck et ses amis
Franck et ses amis
