ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-02-13T12:17:53+01:00 https://brainmodular.org/forums/app.php/feed/topic/1728 2010-02-13T12:17:53+01:00 2010-02-13T12:17:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=11577#p11577 <![CDATA[loadpatch]]> http://sensomusic.com/wiki/doku.php?id= ... al_loading
Statistics: Posted by senso — 13 Feb 2010, 12:17
2010-02-12T23:13:25+01:00 2010-02-12T23:13:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=11574#p11574 <![CDATA[loadpatch]]> ;-)
Statistics: Posted by nay-seven — 12 Feb 2010, 23:13
2010-02-12T23:08:04+01:00 2010-02-12T23:08:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=11573#p11573 <![CDATA[loadpatch]]> http://www.sensomusic.com/wiki/doku.php?id=manual:guide I absolutely cannot see a Tips section. Am I blind?
Statistics: Posted by gurulogic — 12 Feb 2010, 23:08
2010-02-12T22:55:40+01:00 2010-02-12T22:55:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=11570#p11570 <![CDATA[loadpatch]]> http://www.sensomusic.com/wiki/doku.php ... tips:index
Statistics: Posted by nay-seven — 12 Feb 2010, 22:55
2010-02-12T22:44:28+01:00 2010-02-12T22:44:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=11569#p11569 <![CDATA[loadpatch]]> What is the best way to add information like this? Should we maybe start a new section called "Tips and Tricks" or... ?
Statistics: Posted by gurulogic — 12 Feb 2010, 22:44
2010-02-12T22:36:41+01:00 2010-02-12T22:36:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=11568#p11568 <![CDATA[loadpatch]]> maybe you can add your tip in the wiki?
Statistics: Posted by senso — 12 Feb 2010, 22:36
2010-02-12T22:22:40+01:00 2010-02-12T22:22:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=11566#p11566 <![CDATA[loadpatch]]>
my opinion is that I think it's possible to create a patch to format the patch name with the "concat strings" modules to achieve what you want?
Just in case anyone else is ever wondering how to best use the LoadPatch module, I have finally deciphered Senso's cryptic response ...
What I did not understand is the the name inlet is used to tell the LoadPatch module the directory where the patch is, ie C:UsinePatchExample1.pat
-using Concat Strings, String 1 is the directory name, ie: C:UsinePatch
-then you can connect a listbox with the names of all your patches to the inlet of String 2
-then you connect the String out to the name input of the LoadPatch module so as you select from your listbox you end up with C:UsinePatchExample1.pat, C:UsinePatchExample2.pat, C:UsinePatchExample3.pat etc.
So in my opinion, the LoadPatch module is already perfect! (but somewhat poorly documented ;) )
Statistics: Posted by gurulogic — 12 Feb 2010, 22:22
2009-09-17T07:09:35+01:00 2009-09-17T07:09:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=10195#p10195 <![CDATA[loadpatch]]> Actually I don't know if it's juste a display pb or something more dramatic....
I'll take a look.
Statistics: Posted by senso — 17 Sep 2009, 08:09
2009-09-17T06:44:17+01:00 2009-09-17T06:44:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=10193#p10193 <![CDATA[loadpatch]]>
A bit much to wrap my head around at first but I should be able to work with it, though just being able to select a patch name with a listbox connected to the "currently non usefull name input pin" on the Load Patch Module would be much less complex.
(btw, if I connect a text input that says "test1.pat" to the name input of the Load Patch Module, the name reads "dddd1.dad".Is this correct behavior?)
Also I tested moving the patches to another computer and so long as I keep the directory structure the same, the patches load fine so I guess no further suggestions or improvements are really necessary to make this idea work :-)
Thanks for listening...
Statistics: Posted by gurulogic — 17 Sep 2009, 07:44
2009-09-16T23:16:32+01:00 2009-09-16T23:16:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=10188#p10188 <![CDATA[loadpatch]]>
Perhaps I had better take this to the patching questions forum.. I definately do not understand how that would work.
Just to be clear, I wouldn't want to be just loading the 'next' patch always. I would want to be able to select from the ib any patch to load. One other way I see to do this is to have a set number of loadpatch modules in each patch, each one with the name of another patch load choice but this seems overly complex, especially when I change computers and if the root directory changes.
Also, chaining workspaces does not make sense for me as some items would have to remain constant,
but I understand you have higher priorities, and this is just a new idea for me that may not even be all that practical in real world use.
Now to see if I can figure out "concat strings" :-)
Statistics: Posted by gurulogic — 17 Sep 2009, 00:16
2009-09-16T22:57:52+01:00 2009-09-16T22:57:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=10186#p10186 <![CDATA[loadpatch]]> Also the conductor provides a efficient way to chain workspaces.
So, i'm sure that the loadpatch module can be improved but for me it's not the highest priority?
Statistics: Posted by senso — 16 Sep 2009, 23:57
2009-09-16T21:57:24+01:00 2009-09-16T21:57:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=1728&p=10185#p10185 <![CDATA[loadpatch]]> If using realtime patch loading, then it would be possible just to wire up the components that are required for each performance.
As I already use a software to resample a loop to play back during song transitions, loading patches in realtime should work much the same way for me.
That being said, I can already do this is Usine, but it is complicated if I use this approach as the LoadPatch module does not accept text input for selecting the name of the patch to load, presumably because once there is a text input to the patch name, LoadPatch no longer has a refence for the root directory the patches are stored in.
Ideally, and my suggestion is that I could tell the LoadPatch module where the root patch directory was and then a listbox etc. could be used via an input bus to select the name of the next patch to load. (which also reminds me that for some reason I seem unable to send text data over a bus?)
Also, in the hopefull future that an audio send bus can be safely disconnected, the above ideas would have even more function if the LoadPatch module could also be set to load sub patches.
Then again maybe I'm crazy and these ideas are no good...?
Statistics: Posted by gurulogic — 16 Sep 2009, 22:57
I'll take a look.
