ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-09-18T17:08:11+01:00 https://brainmodular.org/forums/app.php/feed/topic/1713 2009-09-18T17:08:11+01:00 2009-09-18T17:08:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10202#p10202 <![CDATA[Usine 4.22f]]> Statistics: Posted by 23fx23 — 18 Sep 2009, 18:08
2009-09-18T06:35:28+01:00 2009-09-18T06:35:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10198#p10198 <![CDATA[Usine 4.22f]]>
You said it was an "easy fix" when I first brought it up..... I'll keep waiting.
--e
Statistics: Posted by woodslanding — 18 Sep 2009, 07:35
2009-09-15T07:58:29+01:00 2009-09-15T07:58:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10141#p10141 <![CDATA[Usine 4.22f]]>
did you get a chance to zero the inputs of audio input busses when they are disconnected?
this problem will be solved in the next major release.
If not, I suppose I will wait to upgrade....
please, it's not really an argument for me! This kind of modification can take more than 3 days to be implemented securely: development, test, package, etc.
Sometime modifications cost nothing : have 1024 VST parameters instead of 512 takes maximum 10 seconds. And others can take much more than appears, and yours needs a deep refoundation of the internal buses system.
So I must include it in a global development perspective, even if I loose an upgrade!
Statistics: Posted by senso — 15 Sep 2009, 08:58
2009-09-15T01:17:16+01:00 2009-09-15T01:17:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10136#p10136 <![CDATA[Usine 4.22f]]>
Statistics: Posted by gurulogic — 15 Sep 2009, 02:17
2009-09-14T22:07:05+01:00 2009-09-14T22:07:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10133#p10133 <![CDATA[Usine 4.22f]]>
Statistics: Posted by woodslanding — 14 Sep 2009, 23:07
2009-09-14T20:22:59+01:00 2009-09-14T20:22:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10132#p10132 <![CDATA[Usine 4.22f]]> Statistics: Posted by grego mondo — 14 Sep 2009, 21:22
2009-09-14T09:23:46+01:00 2009-09-14T09:23:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10126#p10126 <![CDATA[Usine 4.22f]]> Statistics: Posted by multiphone — 14 Sep 2009, 10:23
2009-09-13T22:34:29+01:00 2009-09-13T22:34:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10120#p10120 <![CDATA[Usine 4.22f]]> Statistics: Posted by siegfried — 13 Sep 2009, 23:34
2009-09-13T10:34:15+01:00 2009-09-13T10:34:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10115#p10115 <![CDATA[Usine 4.22f]]> Statistics: Posted by ethnix73 — 13 Sep 2009, 11:34
2009-09-13T09:14:08+01:00 2009-09-13T09:14:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10113#p10113 <![CDATA[Usine 4.22f]]>
Statistics: Posted by amiga909 — 13 Sep 2009, 10:14
2009-09-12T20:56:53+01:00 2009-09-12T20:56:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10108#p10108 <![CDATA[Usine 4.22f]]> Statistics: Posted by nay-seven — 12 Sep 2009, 21:56
2009-09-12T12:36:23+01:00 2009-09-12T12:36:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=1713&p=10106#p10106 <![CDATA[Usine 4.22f]]> Usine [4.22f]
Must be downloaded to replace the 4.22e
fixed bugs
- save problems in the "channel" parameter of the create midi module
[4.22e]
intermediate update. You can skip it if everything works on you system.
fixed bugs
- small bug in the channel parameter of the create midi module
- the grain sampler now works in “loop+next” sample
improvements
- the max number of VST parameters in now 1024
- small synchro problem with the Molar VST
- new "Midi Unpack" script.
Statistics: Posted by senso — 12 Sep 2009, 13:36
--e
fixed bugs
[4.22e]
fixed bugs
improvements
