ArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-09-10T17:56:38+01:00 https://brainmodular.org/forums/app.php/feed/topic/1707 2009-09-10T17:56:38+01:00 2009-09-10T17:56:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=1707&p=10097#p10097 <![CDATA[Rename patch from textfield with IML?]]>
RENAME_PATCH c:usinepatchesmyPatch.pat
then use the 'send message' module process the message.
something like that?
Statistics: Posted by senso — 10 Sep 2009, 18:56
2009-09-10T11:37:42+01:00 2009-09-10T11:37:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=1707&p=10096#p10096 <![CDATA[Rename patch from textfield with IML?]]>
I'm using a textfield module to have a visual feedback on a local interface builder. This string is then sent to others textfield modules, through bus, located in other local interface builder. No problem with this
I would like to be able to rename automatically my sub patch in the patch design panel....
With IML, i can retrieve the outlet from the textfield module, and get the string values. But, can i use set this string as a variable and use it with the rename patch command?
Statistics: Posted by ethnix73 — 10 Sep 2009, 12:37
2009-09-10T07:31:44+01:00 2009-09-10T07:31:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=1707&p=10094#p10094 <![CDATA[Rename patch from textfield with IML?]]> Statistics: Posted by senso — 10 Sep 2009, 08:31
2009-09-07T22:58:58+01:00 2009-09-07T22:58:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=1707&p=10078#p10078 <![CDATA[Rename patch from textfield with IML?]]>
I've done a few test but i haven't been able to do this...
Statistics: Posted by ethnix73 — 07 Sep 2009, 23:58
