2009-09-01T12:00:40+01:002009-09-01T12:00:40+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=10063#p10063Statistics: Posted by RoyG — 01 Sep 2009, 13:00
]]>2009-09-01T11:51:54+01:002009-09-01T11:51:54+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=10062#p10062Statistics: Posted by ethnix73 — 01 Sep 2009, 12:51
]]>2009-09-01T11:22:08+01:002009-09-01T11:22:08+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=10061#p10061 What am I missing?
Should the modules be in a saparate track from the vsts?
Again it seems like everything is going into an endless loop where I cant press any button. Does the order in which I do things matter?
]]>2009-09-01T10:53:19+01:002009-09-01T10:53:19+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=10060#p10060Statistics: Posted by ethnix73 — 01 Sep 2009, 11:53
]]>2009-09-01T07:40:37+01:002009-09-01T07:40:37+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=10059#p10059 It does not seem to work for me. Is it because I'm using the free version (can't edit scripts)?
]]>2009-08-31T22:57:00+01:002009-08-31T22:57:00+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=10057#p10057Statistics: Posted by ethnix73 — 31 Aug 2009, 23:57
]]>2009-08-31T22:08:15+01:002009-08-31T22:08:15+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=10056#p10056will add this to the next "utils compilation " for sure .
and to add a little precision for those who want different name or want understand more : be careful to understand the difference between the name of the in of the module and his proper name for IML :
Statistics: Posted by nay-seven — 31 Aug 2009, 23:08
the first button (send msg1) triggers the first Usine msg module. A value of 1 is sent to the first bus, and 0 to the others.
the second button (send msg2) triggers the second Usine msg module. A value of 1 is sent to second bus, and 0 to the others. aka: TARGET_PATCH SEND_PATCH SET_VALUE 1 1 0 SET_VALUE 2 2 1 SET_VALUE 3 3 0 SET_VALUE 4 4 0
And so on, for the others button and Usinemsg...
Then, you can put a getbus module in each track (as in your second screenshot in your last post), or link a getbus module directly linked to a vsti...
So each button activate a vsti and bypass the others.
Statistics: Posted by ethnix73 — 31 Aug 2009, 22:07
]]>2009-08-31T20:51:22+01:002009-08-31T20:51:22+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=10054#p10054Statistics: Posted by nay-seven — 31 Aug 2009, 21:51
]]>2009-08-31T18:15:54+01:002009-08-31T18:15:54+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=10050#p10050
Statistics: Posted by ethnix73 — 31 Aug 2009, 19:15
]]>2009-08-31T17:30:50+01:002009-08-31T17:30:50+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=10049#p10049 built this one ( can be adapted to more switch ) 23xx say about it : this might not be the only/best solution but this seems to work well for 2-15 switches. each switch will output 2-3-4-5-6 to the selector that keep the last pressed switch number and send back to the dispatcher that have "set to 0" enabled, so it will switch off all the others, (add constant 1 on input).ps( I don't use input 1 because it will be the default output when switch are off, that's also why it's need to start from 2 , for the selector to select the 2nd
and put this one in each track ( just rename bus as : track 2 , track 3 and so... here , the bus are linked to the mute , but you can use it to bypass a vst or what you want..
Statistics: Posted by nay-seven — 31 Aug 2009, 18:30
]]>2009-08-31T15:21:15+01:002009-08-31T15:21:15+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=10048#p10048 How do I solve that?
]]>2009-08-09T19:33:41+01:002009-08-09T19:33:41+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=9897#p9897you can use the data bus for this and and a math / logical/ not (a ) : the 2 bus module must have the same name
Statistics: Posted by nay-seven — 09 Aug 2009, 20:33
]]>2009-08-09T17:52:06+01:002009-08-09T17:52:06+01:00https://brainmodular.org/forums/viewtopic.php?t=1683&p=9895#p9895 I'm pretty much a Usine noob. I'm a guitarist and am setting up to run amp simulators from a laptop. I currently have an instance of Amplitube2 on track 1 and an instance of Guitar Rig 3 on track 2. I'll be using Preset Managers with them and there are times where I'll need only one active, but sometimes both. How do I automagically bypass one when switching to the other? I'm assuming this saves CPU like it does in Bidule?
