ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-07-21T10:06:38+01:00 https://brainmodular.org/forums/app.php/feed/topic/1660 2009-07-21T10:06:38+01:00 2009-07-21T10:06:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9777#p9777 <![CDATA["Paul's Extreme Sound Stretch" sampler]]> also i betatested for Darrels DtBlkFx.
you can find in it several modules designed by me. one is called "waka's spectral splitter" if i remember correctly :)
( my nickname is waka x )
and no - fft fx are not realtime :) still have latency ! not big one but still ...
in DtBlkFx - you can choose the size of the latency / buffer.
some hosts can compensate the latency.
Statistics: Posted by Felix_Petrescu — 21 Jul 2009, 11:06
2009-07-21T08:01:06+01:00 2009-07-21T08:01:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9775#p9775 <![CDATA["Paul's Extreme Sound Stretch" sampler]]> and felix is right too there probably isnt anything in the vst domain for 'granular extreme timestretch'.
if u are looking for vst stuff u maybe didnt know: spectral or fft driven plugs could maybe u give this effect in realtime. like the mentioned DtBlkFx or on the commercial side spectron by izotope or the fairly unkown spectrumworx by delaydot.
Statistics: Posted by amiga909 — 21 Jul 2009, 09:01
2009-07-20T23:57:10+01:00 2009-07-20T23:57:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9774#p9774 <![CDATA["Paul's Extreme Sound Stretch" sampler]]> Statistics: Posted by Clearscreen — 21 Jul 2009, 00:57
2009-07-20T15:32:38+01:00 2009-07-20T15:32:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9771#p9771 <![CDATA["Paul's Extreme Sound Stretch" sampler]]> i use timestretchers from Reaper.
quite a lot of algorytms and fast / great sounding.
i just wanted this Paul Stretcher as FSU device :)
Statistics: Posted by Felix_Petrescu — 20 Jul 2009, 16:32
2009-07-20T14:15:58+01:00 2009-07-20T14:15:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9770#p9770 <![CDATA["Paul's Extreme Sound Stretch" sampler]]>
yes, if u look at this way, dblue stretch is a stutter. like mdsp livecut or the infamous supatrigga.
and yes, timestretch isnt possible in realtime, the audio is buffered and then mangled. thus, stretch features a buffer that is much longer than in usual stutter fx.
however, if u can afford it, there is edison vst by imageline. its alike audacity or audition and u can timestretch a selected region in in the wave display.
to have it directly in usine would be better of course. i'd opt for integrating offline-procedures somehow in the sample pool or in the sequencer window since all other modules have real-time in+outlets.
Statistics: Posted by amiga909 — 20 Jul 2009, 15:15
2009-07-20T13:43:44+01:00 2009-07-20T13:43:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9769#p9769 <![CDATA["Paul's Extreme Sound Stretch" sampler]]> thats why is realtime. like old overused jungle stretch from akai samplers :)
Statistics: Posted by Felix_Petrescu — 20 Jul 2009, 14:43
2009-07-20T13:06:00+01:00 2009-07-20T13:06:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9768#p9768 <![CDATA["Paul's Extreme Sound Stretch" sampler]]>
personally, i like realtime stretching better, made recently a little demo with dblue stretch (see link above), wiith a stupid little acid pattern: http://thaumat.org/tmp/dblueStretch_simpleDemo.mp3
also used stretch for live recorded vocals, worked great :)
Statistics: Posted by amiga909 — 20 Jul 2009, 14:06
2009-07-20T10:28:28+01:00 2009-07-20T10:28:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9766#p9766 <![CDATA["Paul's Extreme Sound Stretch" sampler]]> but is amazing tool for blurring and extreme timestretching with good results. sort of ambientizer / lush-elizer.
Can't be made realtime. I mean - it can't process the audio input without latency ( obviously ).
So it could work as a sampler feature in Usine.
And remember that Paul's Stretch is FFT based - not granular !
i abused Paul's with good cheesy ( i hope) results in this (free) ep:
( EP dedicated to old VHS only movies from our childhood )
DOWNLOAD:
http://www.tmbase.ro/media_mp3/mabento_millano.zip
Statistics: Posted by Felix_Petrescu — 20 Jul 2009, 11:28
2009-07-18T09:22:51+01:00 2009-07-18T09:22:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9756#p9756 <![CDATA["Paul's Extreme Sound Stretch" sampler]]> if ur going at realistic time-stretch effects, paul stretch isnt bad but its easily outplayed by the majors in this field (melodyne, cubase time warp, prosoniq time factory, etc.). of course the time stretch in Live or Reaper is very good too - i just want to say that a LOT goes into a realistic stretcher.
however, if u go at it from an experimental view, there really are a lot of tools that can give u the effects of extreme time stretching:
like some of the smartelectronix plugs (ioplong, dfx), Darrell Tams DtBlkFx, or whitelabel stwetch (up to 500% expansion), and many more!
however, i'd love to see the paulstretcher as realtime app too. at least, i've seen paulstretch has been ported to Audacity.
Statistics: Posted by amiga909 — 18 Jul 2009, 10:22
2009-07-17T23:54:47+01:00 2009-07-17T23:54:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9755#p9755 <![CDATA["Paul's Extreme Sound Stretch" sampler]]> Statistics: Posted by Clearscreen — 18 Jul 2009, 00:54
2009-07-17T14:28:30+01:00 2009-07-17T14:28:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9752#p9752 <![CDATA["Paul's Extreme Sound Stretch" sampler]]>
rubberizer vst
http://scuzzphut.com/?p=48
dblue stretch // the timestretch effect in glitch as a single plugin
http://www.gersic.com/plugins/hosted/dblue_VST.rar
Statistics: Posted by amiga909 — 17 Jul 2009, 15:28
2009-07-15T09:11:24+01:00 2009-07-15T09:11:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9716#p9716 <![CDATA["Paul's Extreme Sound Stretch" sampler]]>
Statistics: Posted by Felix_Petrescu — 15 Jul 2009, 10:11
2009-07-15T08:43:05+01:00 2009-07-15T08:43:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9715#p9715 <![CDATA["Paul's Extreme Sound Stretch" sampler]]> Statistics: Posted by senso — 15 Jul 2009, 09:43
2009-07-15T07:35:28+01:00 2009-07-15T07:35:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=1660&p=9709#p9709 <![CDATA["Paul's Extreme Sound Stretch" sampler]]> could be damn useful !
http://hypermammut.sourceforge.net/paulstretch/
sources are free.
Statistics: Posted by Felix_Petrescu — 15 Jul 2009, 08:35
DOWNLOAD:
rubberizer vst
sources are free.
