ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2009-06-08T11:16:41+01:00https://brainmodular.org/forums/app.php/feed/topic/16012009-06-08T11:16:41+01:002009-06-08T11:16:41+01:00https://brainmodular.org/forums/viewtopic.php?t=1601&p=9212#p9212Statistics: Posted by 23fx23 — 08 Jun 2009, 12:16
2009-06-08T11:08:47+01:002009-06-08T11:08:47+01:00https://brainmodular.org/forums/viewtopic.php?t=1601&p=9211#p9211It's a kind of clone of the master synchro and takes no memory neither CPU.
I don't know if i make mistake, but when i activate a master sync, clicking on it doesn't display it in the pach, local works?
was'nt the same since a while...? it's why he is named "low cpu" maybe...
Statistics: Posted by nay-seven — 07 Jun 2009, 23:50
]]>2009-06-07T14:07:29+01:002009-06-07T14:07:29+01:00https://brainmodular.org/forums/viewtopic.php?t=1601&p=9205#p9205Statistics: Posted by 23fx23 — 07 Jun 2009, 15:07
]]>2009-06-06T11:58:48+01:002009-06-06T11:58:48+01:00https://brainmodular.org/forums/viewtopic.php?t=1601&p=9200#p9200 great efforts have been made to make it more accessible for newcomers .
in next days, i'll update/extend wiki pages to reflect these changes.
Statistics: Posted by martignasse — 06 Jun 2009, 12:58
]]>2009-06-05T16:50:37+01:002009-06-05T16:50:37+01:00https://brainmodular.org/forums/viewtopic.php?t=1601&p=9192#p9192Statistics: Posted by runagate — 05 Jun 2009, 17:50
]]>2009-06-05T13:43:47+01:002009-06-05T13:43:47+01:00https://brainmodular.org/forums/viewtopic.php?t=1601&p=9191#p9191and the fact that arrays work with all logical is just opening a new wide range of possibilities .tested work like a charm. thanks again for your great job.
recommended update - solve a important audio Freeze bug. - Implementation of a new SDK (thanks to Martin Fleurent). We anticipate on the futures versions of Usine and the new SDK will be compatible with next versions.
improvements
- New C++ SDK v3. Most of user modules have been rewritten with the new SDK to ensure a forward compatibility - logical operators now work for array's: returns array's of 0 or 1. - new Color modules to translate Usine color into RGB or HSL and inverse. - the roll array user module is now included in the package. - fully compatible with Windows7 RC
fixed bugs
- the array editor doesn't work properly - in the sequencer, sometime the first note of the midi player isn't played. - synchro troubles in the sequencer when playing midi loops: the first note can be played twice. - various graphic troubles in the sequencer. - Usine can randomly freeze few seconds in various situations. - various display bugs in sequencer mode. - in the 'Curve of points' module the inlet ArrayX doesn't work
]]>BrainModularBrainModular Users Forum2009-06-08T11:16:41+01:00https://brainmodular.org/forums/app.php/feed/topic/16012009-06-08T11:16:41+01:002009-06-08T11:16:41+01:00https://brainmodular.org/forums/viewtopic.php?t=1601&p=9212#p9212Statistics: Posted by 23fx23 — 08 Jun 2009, 12:16
]]>2009-06-08T11:08:47+01:002009-06-08T11:08:47+01:00https://brainmodular.org/forums/viewtopic.php?t=1601&p=9211#p9211It's a kind of clone of the master synchro and takes no memory neither CPU.
improvements
fixed bugs
