ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-06-12T23:39:24+01:00 https://brainmodular.org/forums/app.php/feed/topic/1597 2009-06-12T23:39:24+01:00 2009-06-12T23:39:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9297#p9297 <![CDATA[new add on : XY color seq]]>
Statistics: Posted by Clearscreen — 13 Jun 2009, 00:39
2009-06-12T20:22:08+01:00 2009-06-12T20:22:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9296#p9296 <![CDATA[new add on : XY color seq]]>
fixed note stuck (data is blocked when the sequencer start to read a note), implemented absolute/relative mode better for not loosing previous setting. color choice for pointer and note reached. however for me the "step behind" was more a disturbing visual latency problem, if running at very low tempo steps seems ok, so added a fader to conpensate visual sync drift.
note thate index goes from 0 to 15 but corespond ro 1 16, maybe that what you were meaning?
Statistics: Posted by 23fx23 — 12 Jun 2009, 21:22
2009-06-12T15:33:50+01:00 2009-06-12T15:33:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9295#p9295 <![CDATA[new add on : XY color seq]]> Statistics: Posted by 23fx23 — 12 Jun 2009, 16:33
2009-06-12T08:11:06+01:00 2009-06-12T08:11:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9293#p9293 <![CDATA[new add on : XY color seq]]>
also, i seeing a lot of stuck notes, i think from the gate length changing constantly when i'm touching the cell - i think maybe setting it up so the change isn't made until you lift you finger would eliminate this problem?
otherwise this is a brilliant piece of work! :)
Statistics: Posted by Clearscreen — 12 Jun 2009, 09:11
2009-06-11T18:39:58+01:00 2009-06-11T18:39:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9287#p9287 <![CDATA[new add on : XY color seq]]> Statistics: Posted by 23fx23 — 11 Jun 2009, 19:39
2009-06-11T11:32:16+01:00 2009-06-11T11:32:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9281#p9281 <![CDATA[new add on : XY color seq]]>
I tried to do it with panels to act like switches for myself, but yeah my skills are not very high yet!!! ^^
so thanks once again! :)
art.
Statistics: Posted by artificial — 11 Jun 2009, 12:32
2009-06-11T00:19:23+01:00 2009-06-11T00:19:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9274#p9274 <![CDATA[new add on : XY color seq]]> ) , it was weird with swichs( amouse down is needed, they don't havesome) so i found a solution with panels acting as if they were swich (should be same result, you have 16 visible outputs, only one is active at same time)
in fact it's a 16x tab pannels (acting as list box but can be placed where you want) with XY absolute/relative gestion (relative avoid jumps, absolute can be useful, then there is a setting for default value).
http://www.sensomusic.com/forums/upload ... Ytabz2.pat
note you need 4.22 version.
Statistics: Posted by 23fx23 — 11 Jun 2009, 01:19
2009-06-10T21:30:02+01:00 2009-06-10T21:30:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9270#p9270 <![CDATA[new add on : XY color seq]]> Statistics: Posted by 23fx23 — 10 Jun 2009, 22:30
2009-06-10T20:32:52+01:00 2009-06-10T20:32:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9269#p9269 <![CDATA[new add on : XY color seq]]>
btw, would it be possible to add xy-gesture detection also to switches (instead of using "seperator and panel")?
i mean, as long as i click on a switch to activate it, it should detect the xy gesture...
because i try to build a sort of tenori-on grid sequencer and i want to use the "tabs addon" for switching between the different "patterns" (on the tenori-on they are called "layers") and so i was thinking of using the tab switches also as sort of mixer faders to adjust the volume of each pattern.... hope you got what i mean!! ^^ cheers!
Statistics: Posted by artificial — 10 Jun 2009, 21:32
2009-06-03T23:21:05+01:00 2009-06-03T23:21:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9180#p9180 <![CDATA[new add on : XY color seq]]> oops checked forgot to copy paste the colr selector, deleted, new link:
http://www.sensomusic.com/forums/upload ... Cellz2.pat
Statistics: Posted by 23fx23 — 04 Jun 2009, 00:21
2009-06-03T23:01:37+01:00 2009-06-03T23:01:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9179#p9179 <![CDATA[new add on : XY color seq]]>
that helps me very much!! thanks again! :)
Statistics: Posted by artificial — 04 Jun 2009, 00:01
2009-06-03T22:51:06+01:00 2009-06-03T22:51:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9178#p9178 <![CDATA[new add on : XY color seq]]> http://www.sensomusic.com/forums/upload ... xCellz.pat
much more simplified version, noXY, more clear, tried to explained a little how subpach work, hope it can help,
think if you don't want to bother you can dupicate the pach to the nb you need.
Statistics: Posted by 23fx23 — 03 Jun 2009, 23:51
2009-06-03T22:39:17+01:00 2009-06-03T22:39:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9176#p9176 <![CDATA[new add on : XY color seq]]>
cheers.
artificial
Statistics: Posted by artificial — 03 Jun 2009, 23:39
2009-06-03T19:23:41+01:00 2009-06-03T19:23:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9171#p9171 <![CDATA[new add on : XY color seq]]> Statistics: Posted by 23fx23 — 03 Jun 2009, 20:23
2009-06-03T18:39:53+01:00 2009-06-03T18:39:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9170#p9170 <![CDATA[new add on : XY color seq]]>
woooow, great work!
based on this addon i try to create a 16x16 maxtrix sequencer (something similar to the tenori-on), but for me it is really hard to understand your structure/dataflow... because I'm kinda new to patching... so I just wanted to ask you, if you could upload the "simple sequencer" without all the x/y functions (I know, I could just take the stepmidi module, but I love your version with the buttons... because it reminds me of a tenori-on or monome! ;)
thanks in advance! :)
artificial.
Statistics: Posted by artificial — 03 Jun 2009, 19:39
2009-06-01T23:01:54+01:00 2009-06-01T23:01:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9156#p9156 <![CDATA[new add on : XY color seq]]>
changes:
- fixed color change bug
- extended color choice to 7 (red yellow green cyan blue purple grey)
- faders for better visual feedback.
- disable saturation option (might be disturbing)
- implemented pich gestion
- modulation matrix: X and Y can control velocity,gate or pich independantly.
- compatible with preset manager: each pattern can be saved and recalled.
- panic button if note would be blocked (but normally shouldn't be possible).
pich work like this: if you choose X to control pich, midle value (when you enable a cell) is note base unchanged and go from -12 to +12 around it.
Statistics: Posted by 23fx23 — 02 Jun 2009, 00:01
2009-06-01T02:19:03+01:00 2009-06-01T02:19:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9143#p9143 <![CDATA[new add on : XY color seq]]>
Statistics: Posted by Clearscreen — 01 Jun 2009, 03:19
2009-05-31T22:37:27+01:00 2009-05-31T22:37:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=1597&p=9137#p9137 <![CDATA[new add on : XY color seq]]>
It's a 16 step sequencer that can have two values XY stored per step if you keep on pressing a cell and move the mouse/finger.
seems interesting for live situations, if you need to visualise more the values there are arrays inside the pach from you can extract values to faders (for gate/vel ect) by default it sets velocity and gate but you can reuse XY for other things...
little exemple application with helios gates and velocity to cutoff.
next step is to integrate this idea to the square add on and recall 32 pages of 16 steps..
but maybe some beta testing first?
addons/others
edit: arf bug when chg color, later.. so warning should stay on green default for now. hrhr
Statistics: Posted by 23fx23 — 31 May 2009, 23:37
art.
cheers.
artificial
woooow, great work!
artificial.
changes:
addons/others
