ArrayArrayArray BrainModular BrainModular Users Forum 2009-05-29T01:02:04+01:00 https://brainmodular.org/forums/app.php/feed/topic/1592 2009-05-29T01:02:04+01:00 2009-05-29T01:02:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=1592&p=9087#p9087 <![CDATA[SeqX8]]>
Statistics: Posted by Clearscreen — 29 May 2009, 02:02
2009-05-28T22:49:34+01:00 2009-05-28T22:49:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=1592&p=9085#p9085 <![CDATA[SeqX8]]> thanks to share..
Statistics: Posted by nay-seven — 28 May 2009, 23:49
2009-05-27T20:23:31+01:00 2009-05-27T20:23:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=1592&p=9072#p9072 <![CDATA[SeqX8]]>
Here is an attemp to make an eight tracks sequencer with 16 steps. You can trigg 4 midi part, 3 samplers, and one drum step sequencer (from senso). For each step of the sequencer, you can choose the sequence you want to be played. For the moment, there is only 16 steps.
If you want, each midi part or sampler can be recorded in real time, and will be synchronised. They can be used as live loopers ( the sampler are Senso's patch).
You can enter the name of each midi part or sampler part (respectively in each interface), and the name will appear in the "seq" interface and in the top parent interface.
You can go forward or backward in the "seq" interface or use the "pad" interface to trigg the sequence you want...
It's a beta version, and it's still buggy to trigg seq switch (as in the modded version of the roller sequencer from senso...
Next step is to resolve this bug, and to modify the seq to have more than 16 steps.
P.S: there was a sync bug between sequence in the first uploaded version. it's fixed.
Statistics: Posted by ethnix73 — 27 May 2009, 21:23
