ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2006-10-27T09:53:04+01:00 https://brainmodular.org/forums/app.php/feed/topic/159 2006-10-27T09:53:04+01:00 2006-10-27T09:53:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=159&p=720#p720 <![CDATA[Fade in/out to avoid clicks when bypassing/muting]]>
I will take a look.
In that precise case, if you can?t wait, try to make a sub patch which does the fade. (less than 2 minutes?)
Thanks for all your feedbacks.
They are very important for me.
Statistics: Posted by senso — 27 Oct 2006, 10:53
2006-10-27T08:06:14+01:00 2006-10-27T08:06:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=159&p=718#p718 <![CDATA[Fade in/out to avoid clicks when bypassing/muting]]>
I will take a look.
Statistics: Posted by senso — 27 Oct 2006, 09:06
2006-10-26T23:18:07+01:00 2006-10-26T23:18:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=159&p=714#p714 <![CDATA[Fade in/out to avoid clicks when bypassing/muting]]>
(i was able to convince bidule coders ;) )
thanx for the last great update man
Statistics: Posted by lalo — 27 Oct 2006, 00:18
2006-10-18T11:28:22+01:00 2006-10-18T11:28:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=159&p=693#p693 <![CDATA[Fade in/out to avoid clicks when bypassing/muting]]> I understant that it can be a problem for the "aural fascination of the performance"!
So I've implemented a very short fade In/out on track mixer buttons:
MUTE
SOLO
ON/OFF
In then next realase
For the Bybass Button on VST's things are more complex.
In that case, it's not a fadeIn/out but more a crossfade between incoming sound and processed sound. (the bypass on VST's means audio pass thru)
I recommend you to make it with a Crossfade or Volume module.
Statistics: Posted by senso — 18 Oct 2006, 12:28
2006-10-18T08:34:12+01:00 2006-10-18T08:34:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=159&p=691#p691 <![CDATA[Fade in/out to avoid clicks when bypassing/muting]]> often during the liveset i have to mute or bypass an effect or in general an audio process...always a click came out...wich is a bit annoying for the aural
fascination of the performance :)
..how about infinitesimal fade in/out option to avoid this?
thanx
Statistics: Posted by lalo — 18 Oct 2006, 09:34
I will take a look.
I will take a look.
MUTE
SOLO
ON/OFF
thanx
