ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-05-26T17:08:54+01:00 https://brainmodular.org/forums/app.php/feed/topic/1585 2009-05-26T17:08:54+01:00 2009-05-26T17:08:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9055#p9055 <![CDATA[Samplers again]]> Statistics: Posted by stanlea — 26 May 2009, 18:08
2009-05-26T05:58:59+01:00 2009-05-26T05:58:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9048#p9048 <![CDATA[Samplers again]]> midi in -->piano roll-->your sampler or vsti
save this as a patch"my midi.pat "
then drag and drop this patch on a track of the sequencer...
is this what you mean..?
Statistics: Posted by nay-seven — 26 May 2009, 06:58
2009-05-25T22:00:38+01:00 2009-05-25T22:00:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9042#p9042 <![CDATA[Samplers again]]> Statistics: Posted by stanlea — 25 May 2009, 23:00
2009-05-24T22:57:25+01:00 2009-05-24T22:57:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9018#p9018 <![CDATA[Samplers again]]> if you want play manually , the first patch is ok..
if you want use loop mode..so...it's loop mode.."grin"
sorry..don't follow you..
Statistics: Posted by nay-seven — 24 May 2009, 23:57
2009-05-24T22:30:21+01:00 2009-05-24T22:30:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9016#p9016 <![CDATA[Samplers again]]> Statistics: Posted by stanlea — 24 May 2009, 23:30
2009-05-24T22:24:07+01:00 2009-05-24T22:24:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9015#p9015 <![CDATA[Samplers again]]>
but I can't control the flow
what do you mean..?
the problem is that the sampler can't ply several waves at the same time
just add others sampler module linked the same way...?
Statistics: Posted by nay-seven — 24 May 2009, 23:24
2009-05-24T22:19:14+01:00 2009-05-24T22:19:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9014#p9014 <![CDATA[Samplers again]]>
so bad
Statistics: Posted by stanlea — 24 May 2009, 23:19
2009-05-24T22:02:35+01:00 2009-05-24T22:02:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9013#p9013 <![CDATA[Samplers again]]> Statistics: Posted by nay-seven — 24 May 2009, 23:02
2009-05-24T21:47:02+01:00 2009-05-24T21:47:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9012#p9012 <![CDATA[Samplers again]]>
edit : ok, I found all except the element = where is it ?
edit 2 : ok I find all
Statistics: Posted by stanlea — 24 May 2009, 22:47
2009-05-24T21:23:51+01:00 2009-05-24T21:23:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9011#p9011 <![CDATA[Samplers again]]> ;-)
Statistics: Posted by nay-seven — 24 May 2009, 22:23
2009-05-24T21:00:43+01:00 2009-05-24T21:00:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9008#p9008 <![CDATA[Samplers again]]> So each time I press the same key (C3 for instance), the sampler plays a random sample from the sample set, but plays it fully.
Statistics: Posted by stanlea — 24 May 2009, 22:00
2009-05-24T17:57:13+01:00 2009-05-24T17:57:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9005#p9005 <![CDATA[Samplers again]]> Image
this way you can choose the midi note who play the sample and even if you replay the same note , it works...
of , course the sampler is set to " play button"
second question : yes it's normal ...
Statistics: Posted by nay-seven — 24 May 2009, 18:57
2009-05-24T16:25:37+01:00 2009-05-24T16:25:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=1585&p=9004#p9004 <![CDATA[Samplers again]]>
Question 2 : actually, I can't get the sampler to play several samples at the same time, it works with only one voice. Normal ?
Statistics: Posted by stanlea — 24 May 2009, 17:25
what do you mean..?
so bad
