ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2009-05-25T21:42:47+01:00https://brainmodular.org/forums/app.php/feed/topic/15742009-05-25T21:42:47+01:002009-05-25T21:42:47+01:00https://brainmodular.org/forums/viewtopic.php?t=1574&p=9040#p9040Statistics: Posted by bsork — 25 May 2009, 22:42
2009-05-25T20:11:56+01:002009-05-25T20:11:56+01:00https://brainmodular.org/forums/viewtopic.php?t=1574&p=9038#p9038 (so less complex than mine, hehe), adjustable,storable to pm an low cpu cool. I just adapted a bit cause actually if you move the fader the values would updtate the array, just added a pass after it linked to the same button and exactly what i needed, a very cool insert sub array pach. I needed lot instances in my square setup, my solution was locked on each 16 pos, weirdly wired and costed far too much Cpu, you reaaaly made my day.. thanks again master bsork.
]]>2009-05-25T11:23:10+01:002009-05-25T11:23:10+01:00https://brainmodular.org/forums/viewtopic.php?t=1574&p=9030#p9030Statistics: Posted by 23fx23 — 25 May 2009, 12:23
]]>2009-05-25T07:37:00+01:002009-05-25T07:37:00+01:00https://brainmodular.org/forums/viewtopic.php?t=1574&p=9029#p9029
]]>2009-05-22T16:52:28+01:002009-05-22T16:52:28+01:00https://brainmodular.org/forums/viewtopic.php?t=1574&p=8956#p8956 for example if scroll is 0 the 16 values of small array are routed to 16 first values of the 128 array, if i scroll +16, the values are routed to 17-31 ect, any ideas? in fact It's kind of reverse fonction of "extract subarray", would be "insert sub array" at specified pos... is it possible?
]]>BrainModularBrainModular Users Forum2009-05-25T21:42:47+01:00https://brainmodular.org/forums/app.php/feed/topic/15742009-05-25T21:42:47+01:002009-05-25T21:42:47+01:00https://brainmodular.org/forums/viewtopic.php?t=1574&p=9040#p9040Statistics: Posted by bsork — 25 May 2009, 22:42
]]>2009-05-25T20:11:56+01:002009-05-25T20:11:56+01:00https://brainmodular.org/forums/viewtopic.php?t=1574&p=9038#p9038 (so less complex than mine, hehe), adjustable,storable to pm an low cpu cool. I just adapted a bit cause actually if you move the fader the values would updtate the array, just added a pass after it linked to the same button and exactly what i needed, a very cool insert sub array pach. I needed lot instances in my square setup, my solution was locked on each 16 pos, weirdly wired and costed far too much Cpu, you reaaaly made my day.. thanks again master bsork.
