]]>2009-05-18T17:26:24+01:002009-05-18T17:26:24+01:00https://brainmodular.org/forums/viewtopic.php?t=1565&p=8875#p8875 I think I've mentioned this before, but II note that the following patch does not work:
patch 1 audioSource1 --> fxSend_level --> send to buss_1 patch 2 audioSource2 --> fxSend_level -->send to buss_1 patch 3 receive from buss_1 --> audioEffect
only one of the sources is received at the buss destination. Is there a necessity for this behaviour? I just want be able to use a buss as an fx send.
I can patch this way:
patch 1 audioSource1 --> fxSend_level --> send to buss_1A patch 2 audioSource2 --> fxSend_level -->send to buss_1B patch 3 receive from buss_1A --> audioEffect receive from buss_1B --> audioEffect
But it's going to create a huge number more modules. I was using a combo to dynamically reassign the buss send, and that works great, but only for one channel at a time!
Just wondering why this is not supported, and whether it will change in future (or maybe it's actually a bug?) before I start creating all those wires. I thought the bussing would make creation of a matrix mixer really transparent, but it's not so true with the current behaviour.
It's so helpful that Usine automatically mixes cables. It makes sense that busses would work the same way.....
Thanks, -eric
Statistics: Posted by woodslanding — 18 May 2009, 18:26
]]>BrainModularBrainModular Users Forum2009-05-25T02:48:29+01:00https://brainmodular.org/forums/app.php/feed/topic/15652009-05-25T02:48:29+01:002009-05-25T02:48:29+01:00https://brainmodular.org/forums/viewtopic.php?t=1565&p=9027#p9027Statistics: Posted by woodslanding — 25 May 2009, 03:48
]]>2009-05-23T10:21:42+01:002009-05-23T10:21:42+01:00https://brainmodular.org/forums/viewtopic.php?t=1565&p=8967#p8967the last 'send to buse' module rewrite (cancel) previous values.
Thanks, -eric
