Statistics: Posted by héliouk 6 — 15 May 2009, 18:22
]]>2009-05-14T12:58:12+01:002009-05-14T12:58:12+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8816#p8816 The A>=B module can get a value from 0 to "don't know ow many".
It doesn't work for you?
Statistics: Posted by ethnix73 — 14 May 2009, 13:58
]]>2009-05-14T12:40:19+01:002009-05-14T12:40:19+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8814#p8814Statistics: Posted by héliouk 6 — 14 May 2009, 13:40
]]>2009-05-14T11:37:11+01:002009-05-14T11:37:11+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8813#p8813Statistics: Posted by 23fx23 — 14 May 2009, 12:37
]]>2009-05-14T11:12:28+01:002009-05-14T11:12:28+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8812#p8812Statistics: Posted by ethnix73 — 14 May 2009, 12:12
]]>2009-05-14T00:34:59+01:002009-05-14T00:34:59+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8806#p8806 this seems to work: in 1 for multivar is 1 and in2 is 0 if I well undestood,(if a note exeed specified lengh and only if, it will send the trigger when the note goes off?)
ethnix: clever to use the time ms, but i think will be same pb than my first pic, when receive a note off it will count the time and retrigger if the time between note off and next note on exeed the value, wich is from what i feel, disturbing. have to test but thanks to remind me the" time" module (add the same A=B and pass module than ethnix to filter the note)
if fact i think the best tec must a compiled from booth, the idea of using timems must be more cpu friendly but you have to get separate infos of on and off i think.
Statistics: Posted by ethnix73 — 14 May 2009, 00:58
]]>2009-05-13T21:21:31+01:002009-05-13T21:21:31+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8803#p8803 i'm gonna try your solution now..(did'nt read it yet)...
Statistics: Posted by héliouk 6 — 13 May 2009, 22:21
]]>2009-05-13T20:46:59+01:002009-05-13T20:46:59+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8801#p8801can't test here no audio in but was thinking of sommething like this:
if a note is on and it's the wanted one, then it trigs the counter, when getting note off, stop the counter, check the value elapsed between the two, if > at chosen value then trig out.
edit:, mm should work but could retrigg if you take time after to retrig a new note, don't have solution mmm the counter should only work when sequence is in the order note on then note off and not inverse arf who got a solution
edit:, mm sorry re read, this musn't be what you want
]]>2009-05-13T20:42:08+01:002009-05-13T20:42:08+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8800#p8800now i try midi to audio>>>midi filter>>>code 1 to A=B>>>elapsed time>>>A>B module>>>send bus but doesn't seems to work! i'm gonna try again and again and
Statistics: Posted by héliouk 6 — 13 May 2009, 21:42
Statistics: Posted by nay-seven — 13 May 2009, 17:38
]]>2009-05-13T14:29:58+01:002009-05-13T14:29:58+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8796#p8796Statistics: Posted by héliouk 6 — 13 May 2009, 15:29
]]>2009-05-13T14:13:34+01:002009-05-13T14:13:34+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8795#p8795Statistics: Posted by héliouk 6 — 13 May 2009, 15:13
]]>2009-05-13T13:33:24+01:002009-05-13T13:33:24+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8794#p8794 when you receive the note----> from 0to1 ----->start counting, once reached the amount of ms you specify, will output a stop impulse, link it to trigger what you want.
also not sure understood, if you enter audio in and not midi you should use the audio to midi module to fisrt convert sax to midi notes, and yes then check if A=B to filter the note you want.
]]>2009-05-13T13:29:35+01:002009-05-13T13:29:35+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8793#p8793Statistics: Posted by Clearscreen — 13 May 2009, 14:29
]]>2009-05-13T13:22:31+01:002009-05-13T13:22:31+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8792#p8792my problem of the day is to trigger a vst from a sustained note from saxophone.. so i have my midi to audio link to the midi filter to get the code 1 (midi note) from the sax, linked to A=B module to select wich note i want,but i don't know how to say:dear usine,i want to trigger my effect only if the note is sustained a certain time.i'm looking in syncro and time modules but i don't find....an idea?
Statistics: Posted by héliouk 6 — 13 May 2009, 14:22
]]>BrainModularBrainModular Users Forum2009-05-15T17:33:05+01:00https://brainmodular.org/forums/app.php/feed/topic/15562009-05-15T17:33:05+01:002009-05-15T17:33:05+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8834#p8834Statistics: Posted by héliouk 6 — 15 May 2009, 18:33
]]>2009-05-15T17:27:10+01:002009-05-15T17:27:10+01:00https://brainmodular.org/forums/viewtopic.php?t=1556&p=8833#p8833
try to make it bigger ??
Statistics: Posted by héliouk 6 — 15 May 2009, 18:27
