ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-05-13T21:03:28+01:00 https://brainmodular.org/forums/app.php/feed/topic/1552 2009-05-13T21:03:28+01:00 2009-05-13T21:03:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=1552&p=8802#p8802 <![CDATA[XY Grain Sampler Pack]]> curves have also ones..if you expand the module .
link to the pitch of a sample give you a great tool
Statistics: Posted by nay-seven — 13 May 2009, 22:03
2009-05-13T00:54:39+01:00 2009-05-13T00:54:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=1552&p=8777#p8777 <![CDATA[XY Grain Sampler Pack]]> Statistics: Posted by 23fx23 — 13 May 2009, 01:54
2009-05-12T23:51:42+01:00 2009-05-12T23:51:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=1552&p=8775#p8775 <![CDATA[XY Grain Sampler Pack]]>
can we have precisions about those new layouts possibilities..?
and what is this
%internal%
You already know that you can skin modules with some bitmap ;)
But the so great thing is that at least one module (WaveDispaly) have a 'bitmap out' pin,
and some other modules (Step, StepSwitch, Lines, XYPad) have a 'Bitmap in' pin
When you connect them together, you have the sample picture of the WaveDisplay as the Background Bitmap of the other module,
the %internal% is to tel you that Usine provide the Background Bitmap, like that :
don't know if there is other module with these functionalities, will surely be extended in future.
just to say until senso explanation...
Statistics: Posted by martignasse — 13 May 2009, 00:51
2009-05-12T22:59:13+01:00 2009-05-12T22:59:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=1552&p=8770#p8770 <![CDATA[XY Grain Sampler Pack]]> can we have precisions about those new layouts possibilities..?
and what is this
%internal%
Statistics: Posted by nay-seven — 12 May 2009, 23:59
2009-05-12T18:46:16+01:00 2009-05-12T18:46:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=1552&p=8763#p8763 <![CDATA[XY Grain Sampler Pack]]>
Statistics: Posted by ethnix73 — 12 May 2009, 19:46
2009-05-12T16:53:06+01:00 2009-05-12T16:53:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=1552&p=8757#p8757 <![CDATA[XY Grain Sampler Pack]]> Statistics: Posted by 23fx23 — 12 May 2009, 17:53
2009-05-12T15:26:01+01:00 2009-05-12T15:26:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1552&p=8753#p8753 <![CDATA[XY Grain Sampler Pack]]>
XY GrainSampler Pitch: adjust the reading position on the X axes and the Pitch on the Y axes
XY GrainSampler Grain: adjust the reading position on the X axes and the Grain size on the Y axes
Also this pack implements the new design and layout possibilities of the version 4.20.
Statistics: Posted by senso — 12 May 2009, 16:26
and what is this
%internal%
and what is this
%internal%
