ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-05-11T23:37:16+01:00 https://brainmodular.org/forums/app.php/feed/topic/1545 2009-05-11T23:37:16+01:00 2009-05-11T23:37:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=1545&p=8730#p8730 <![CDATA[All Patches Of the racks remote control: a bit confused]]>
Statistics: Posted by moody33 — 12 May 2009, 00:37
2009-05-11T22:58:44+01:00 2009-05-11T22:58:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=1545&p=8729#p8729 <![CDATA[All Patches Of the racks remote control: a bit confused]]>
But if you drop the NOT and the Pass because don't want the non-selected switches turned off when you go to another track, the AND should stay.
Statistics: Posted by bsork — 11 May 2009, 23:58
2009-05-11T22:49:09+01:00 2009-05-11T22:49:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=1545&p=8728#p8728 <![CDATA[All Patches Of the racks remote control: a bit confused]]> You're solution do the job very well.
I even think that we don't need the AND module. I've test with a "queue array data " and an array display just after the "midi sw" to see if the switch send something while the track is not selected and while a CC is send. The switch light quickly but don't seems to send any value.
Thanks you professor. You always help me a lot !
Statistics: Posted by moody33 — 11 May 2009, 23:49
2009-05-11T22:14:32+01:00 2009-05-11T22:14:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=1545&p=8727#p8727 <![CDATA[All Patches Of the racks remote control: a bit confused]]>
However, you can make your own "only if track selected" for MIDI - something like this:
The MIDI learn is of course on the "midi sw", while the other is just to show the output.
If you don't need/want to deactivate the switch(es) when the track is not selected,drop the Not and the Pass modules.
Statistics: Posted by bsork — 11 May 2009, 23:14
2009-05-11T18:45:35+01:00 2009-05-11T18:45:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=1545&p=8724#p8724 <![CDATA[All Patches Of the racks remote control: a bit confused]]> I have 4 tracks with 1 patch each. I want to assign the same midi control to a switch in track 1, another to track 2 , another one to track 3 and another on to track 4. BUT, i wan't assigned switch to respond ONLY IF TRACK is select on the grid.
So in the configuration setup, I have disable " all patches of the rack".
However, even if I'm in "rack mode" and even if I have select the track I want to control, All tracks responds to my CC at the same time.
What I v'e missed? any ideas?
Statistics: Posted by moody33 — 11 May 2009, 19:45
