ArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2009-05-14T23:45:20+01:00https://brainmodular.org/forums/app.php/feed/topic/15442009-05-14T23:45:20+01:002009-05-14T23:45:20+01:00https://brainmodular.org/forums/viewtopic.php?t=1544&p=8823#p8823 And then it seems like I need to store that value in a variable, which I can set the name to.
This is the kind of thing I've been experimenting with, but it's not working. I'm trying to get the value of the text output of a combobox called 'instrument'.
SET_TARGET_PATCH SENDER_PATCH GET_VALUE Instrument text inst RENAME_PATCH inst
Thoughts??
Thanks, -eric
Statistics: Posted by woodslanding — 15 May 2009, 00:45
]]>2009-05-14T18:19:58+01:002009-05-14T18:19:58+01:00https://brainmodular.org/forums/viewtopic.php?t=1544&p=8817#p8817 Anybody know that syntax? Or if this will work??
or is there really an input to the message module at all?
thanks, -e
Statistics: Posted by woodslanding — 14 May 2009, 19:19
]]>2009-05-13T21:45:22+01:002009-05-13T21:45:22+01:00https://brainmodular.org/forums/viewtopic.php?t=1544&p=8804#p8804 Interface control ->Usine Panels -> Current Patch Name
and double-clicked it so it shows a text input (it's apparently not active, though) and cabled to that input from the text out on a combo box. The combobox is fed from a commatext of the names of all the instruments, and that name is used to dynamically change all the outputs and sends in the patch. If it could change the name, that's one less thing I have to do manually each time I add an instrument.
-e
Statistics: Posted by woodslanding — 13 May 2009, 22:45
]]>2009-05-13T00:57:37+01:002009-05-13T00:57:37+01:00https://brainmodular.org/forums/viewtopic.php?t=1544&p=8778#p8778 what do you mean by 'patch name object' ? and what input precisely ?
any picture to enlighten us ?
Statistics: Posted by martignasse — 13 May 2009, 01:57
]]>2009-05-13T00:18:44+01:002009-05-13T00:18:44+01:00https://brainmodular.org/forums/viewtopic.php?t=1544&p=8776#p8776Statistics: Posted by woodslanding — 13 May 2009, 01:18
2009-05-11T18:27:10+01:002009-05-11T18:27:10+01:00https://brainmodular.org/forums/viewtopic.php?t=1544&p=8722#p8722Statistics: Posted by woodslanding — 11 May 2009, 19:27
]]>2009-05-11T17:53:41+01:002009-05-11T17:53:41+01:00https://brainmodular.org/forums/viewtopic.php?t=1544&p=8721#p8721 Thanks you martignasse. My needs was only to change the name of the patch, so I'va change the last argument and it works like a charm !
I was afraid about IML, and finally, it seems to be simple. I'll take a deeply look in ILM now. Thanks you !
Statistics: Posted by moody33 — 11 May 2009, 18:53
]]>2009-05-11T17:11:58+01:002009-05-11T17:11:58+01:00https://brainmodular.org/forums/viewtopic.php?t=1544&p=8720#p8720 I made some test and found at least one way to do this
the IML, assuming the UsineMessage module is in the same patch as your sampler and the sampler is named BASS :
Usine seems to graphicly refresh the name of the module when you click in the patch area.
but in a complex workspace, it could be trick to set the TARGET_PATCH
Hope it help
Statistics: Posted by martignasse — 11 May 2009, 18:11
]]>2009-05-11T14:07:52+01:002009-05-11T14:07:52+01:00https://brainmodular.org/forums/viewtopic.php?t=1544&p=8719#p8719 Is there's a way to change patch names dynamically?
I need this because i use a sampler that save random name . so the first letters used are for those files are the patch name. then if I want to name a file before recording, I need to change the patch name!
there is probably a way to do this but I'm confused with ILM. anyone have an idea?
Thanks you.
Statistics: Posted by moody33 — 11 May 2009, 15:07
]]>BrainModularBrainModular Users Forum2009-05-14T23:45:20+01:00https://brainmodular.org/forums/app.php/feed/topic/15442009-05-14T23:45:20+01:002009-05-14T23:45:20+01:00https://brainmodular.org/forums/viewtopic.php?t=1544&p=8823#p8823 And then it seems like I need to store that value in a variable, which I can set the name to.
Thoughts??
Thanks, -eric
thanks, -e
-e
]]>2009-05-11T18:27:10+01:002009-05-11T18:27:10+01:00https://brainmodular.org/forums/viewtopic.php?t=1544&p=8722#p8722Statistics: Posted by woodslanding — 11 May 2009, 19:27
Hope it help
Thanks you.
