ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-05-12T02:26:21+01:00 https://brainmodular.org/forums/app.php/feed/topic/1535 2009-05-12T02:26:21+01:00 2009-05-12T02:26:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8739#p8739 <![CDATA[roll array]]>
i'm working on a spectral oscillator x32 and the scroll function has found his place..;-)
http://www.sensomusic.com/forums/upload ... a_x_32.jpg
seeing this makes me think that an endless knob would be a good thing or the scroll knob - is that possible with usine at the moment?
Statistics: Posted by Clearscreen — 12 May 2009, 03:26
2009-05-10T23:30:34+01:00 2009-05-10T23:30:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8703#p8703 <![CDATA[roll array]]> Statistics: Posted by 23fx23 — 11 May 2009, 00:30
2009-05-10T19:38:40+01:00 2009-05-10T19:38:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8694#p8694 <![CDATA[roll array]]>
I can find you one hehe : not really a bug, but seems to not work with negative values...
yep, a real bug, corrected now.
user module added in addons->data tools.
Statistics: Posted by martignasse — 10 May 2009, 20:38
2009-05-10T18:39:45+01:00 2009-05-10T18:39:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8692#p8692 <![CDATA[roll array]]>
@23fx23
wow, already two intensive use of this user module, and no bug report ?
I'm an happy coder :)
Statistics: Posted by 23fx23 — 10 May 2009, 19:39
2009-05-10T12:53:54+01:00 2009-05-10T12:53:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8686#p8686 <![CDATA[roll array]]> Statistics: Posted by 23fx23 — 10 May 2009, 13:53
2009-05-10T10:59:40+01:00 2009-05-10T10:59:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8680#p8680 <![CDATA[roll array]]> no problem, hope it's just the beginning ;)
You can even look 'inside' the module, as source are available thru the wiki.
@nay-seven
interesting patch you are making here.
Statistics: Posted by martignasse — 10 May 2009, 11:59
2009-05-10T10:49:27+01:00 2009-05-10T10:49:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8679#p8679 <![CDATA[roll array]]>
Statistics: Posted by nay-seven — 10 May 2009, 11:49
2009-05-10T09:57:32+01:00 2009-05-10T09:57:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8677#p8677 <![CDATA[roll array]]>
take your time....and dont forget to make music
hehe very true,just afer finish my next pach :) working on a 16 cells matrix that can receive independant color/caption/togglles quickset and all stored/recalled in pm.
but thank you again martignasse, your module will be sooo useful for me for tons of things..
Statistics: Posted by 23fx23 — 10 May 2009, 10:57
2009-05-09T21:04:26+01:00 2009-05-09T21:04:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8666#p8666 <![CDATA[roll array]]>
ok many thx martignasse, I ll slowly try to learn, see the potential is awesome :)
Statistics: Posted by martignasse — 09 May 2009, 22:04
2009-05-09T20:49:04+01:00 2009-05-09T20:49:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8665#p8665 <![CDATA[roll array]]>
Statistics: Posted by 23fx23 — 09 May 2009, 21:49
2009-05-09T20:36:53+01:00 2009-05-09T20:36:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8664#p8664 <![CDATA[roll array]]>
wiki SDK CPP area
in the Microsoft Softs and Docs section, you have a link to download the free VC EXPRESS (the first one).
and i let you explore the rest ;)
Statistics: Posted by martignasse — 09 May 2009, 21:36
2009-05-09T20:04:15+01:00 2009-05-09T20:04:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8663#p8663 <![CDATA[roll array]]>
the power of user module at show!
I would pay for a formation, will slowly approach the idea, what soft did ya use to create the module?
Statistics: Posted by 23fx23 — 09 May 2009, 21:04
2009-05-09T19:50:50+01:00 2009-05-09T19:50:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8662#p8662 <![CDATA[roll array]]>
here is the link to the user module : <edit>user module added in addons->data tools</edit>
the good thing is they work with sequenced switch. :)
have now to test with lots of instances to estimate the CPU gain.
Statistics: Posted by martignasse — 09 May 2009, 20:50
2009-05-09T19:32:59+01:00 2009-05-09T19:32:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8661#p8661 <![CDATA[roll array]]>
chapeau bas
Statistics: Posted by 23fx23 — 09 May 2009, 20:32
2009-05-09T19:11:15+01:00 2009-05-09T19:11:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8660#p8660 <![CDATA[roll array]]>
not yet finished, but found the time to do the user module incarnation of the now famous Roll Array....tada
shift R and shift L aren't yep implemented, but roll is ok.
sources will come when finished
Statistics: Posted by martignasse — 09 May 2009, 20:11
2009-05-09T16:02:57+01:00 2009-05-09T16:02:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=1535&p=8656#p8656 <![CDATA[roll array]]>
specify the lengh of the array and roll over it. When on 0 nothing done, you can shift positivly to max the array lengh or negatively to same range. cpu load is proportionnal to array lengh so try to keep the lowest needed value.
example apllications: shiftables Lfos/ notes sequences/ any data sequences, maybe roll thru presets...
Statistics: Posted by 23fx23 — 09 May 2009, 17:02
@23fx23
@nay-seven
wiki SDK CPP area
chapeau bas
