Statistics: Posted by woodslanding — 08 May 2009, 10:27
]]>2009-04-26T09:37:28+01:002009-04-26T09:37:28+01:00https://brainmodular.org/forums/viewtopic.php?t=1486&p=8423#p8423I'll take a look to find a way to improve this behavior.
]]>2009-04-26T04:12:57+01:002009-04-26T04:12:57+01:00https://brainmodular.org/forums/viewtopic.php?t=1486&p=8417#p8417 You might want to experiment a little more with lists that have many items. 127 is a typical amount for vstI presets.
-e
Statistics: Posted by woodslanding — 26 Apr 2009, 05:12
only if the touch-screen mode is activated in the setup/interface
where/how do i adjust this?
Statistics: Posted by Clearscreen — 24 Apr 2009, 01:20
]]>2009-04-23T09:58:37+01:002009-04-23T09:58:37+01:00https://brainmodular.org/forums/viewtopic.php?t=1486&p=8367#p8367you re right you can't adjust it but only the size of items.
]]>2009-04-22T12:51:27+01:002009-04-22T12:51:27+01:00https://brainmodular.org/forums/viewtopic.php?t=1486&p=8360#p8360Statistics: Posted by 23fx23 — 22 Apr 2009, 13:51
2009-04-22T07:42:22+01:002009-04-22T07:42:22+01:00https://brainmodular.org/forums/viewtopic.php?t=1486&p=8354#p8354 you said there is a way to adjust the overall size of the popup display in the IB, but I can't find it. I don't want a scroll bar unless the window is too large to fit on my screen. But regardless of the item height and width, I'm still getting a scroll bar at the bottom of some windows that could easily fin onscreen.
I think we need parameters for number of columns, and number of rows, in addition to item height and width.
And actually, a scrollbar in touchscreen mode is not very usable at all. It would be nice to have the option to replace it with prevPage and nextPage buttons
thanks! -eric
Statistics: Posted by woodslanding — 22 Apr 2009, 08:42
-e
]]>2009-04-22T07:42:22+01:002009-04-22T07:42:22+01:00https://brainmodular.org/forums/viewtopic.php?t=1486&p=8354#p8354 you said there is a way to adjust the overall size of the popup display in the IB, but I can't find it. I don't want a scroll bar unless the window is too large to fit on my screen. But regardless of the item height and width, I'm still getting a scroll bar at the bottom of some windows that could easily fin onscreen.
thanks! -eric
