ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-04-22T08:24:01+01:00 https://brainmodular.org/forums/app.php/feed/topic/1485 2009-04-22T08:24:01+01:00 2009-04-22T08:24:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1485&p=8356#p8356 <![CDATA[Usine 4.20 beta7 another important bug fixed]]> will be fixed in the week.
Statistics: Posted by senso — 22 Apr 2009, 09:24
2009-04-22T07:46:42+01:00 2009-04-22T07:46:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=1485&p=8355#p8355 <![CDATA[Usine 4.20 beta7 another important bug fixed]]> Statistics: Posted by woodslanding — 22 Apr 2009, 08:46
2009-04-21T20:22:54+01:00 2009-04-21T20:22:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=1485&p=8348#p8348 <![CDATA[Usine 4.20 beta7 another important bug fixed]]> I do get 10% or so better CPU performance with a bloc size of 256...
Statistics: Posted by gurulogic — 21 Apr 2009, 21:22
2009-04-21T19:55:06+01:00 2009-04-21T19:55:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=1485&p=8347#p8347 <![CDATA[Usine 4.20 beta7 another important bug fixed]]> Statistics: Posted by senso — 21 Apr 2009, 20:55
2009-04-21T19:41:32+01:00 2009-04-21T19:41:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=1485&p=8346#p8346 <![CDATA[Usine 4.20 beta7 another important bug fixed]]> Statistics: Posted by gurulogic — 21 Apr 2009, 20:41
2009-04-21T14:37:53+01:00 2009-04-21T14:37:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=1485&p=8340#p8340 <![CDATA[Usine 4.20 beta7 another important bug fixed]]>
Whaouuu!! Usine seriously rock now !!!!
Statistics: Posted by noise2sine — 21 Apr 2009, 15:37
2009-04-21T14:22:39+01:00 2009-04-21T14:22:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=1485&p=8339#p8339 <![CDATA[Usine 4.20 beta7 another important bug fixed]]> [4.2 beta 7]
Multi-Core Version
Important bugs solved.
fixed bugs
- important refresh GUI bug
[4.2 beta 6]
Multi-Core Version
Important VST bugs solved.
improvements
- Quad-Core optimization
fixed bugs
- important bug when loading VST's
[4.2 beta 5]
Multi-Core Version
Major release with more than 100 improvements.
This is probably the most stable Usine we never had but is still a beta version because new real multi-core optimization.
Take a look on the demo files to have an idea of what we can now do with Usine, especially in personal interface design.
improvements
- real Multi-Core CPU optimization
- auto reorganization of windows in the interface builder: It's an option of the IB layout (see the manual)
- new dashboard and master synchro design,
- auto show option in the conductor lite window
- new midi mode option "Interface builder windows order"
- get buses list module
- current patch name module
- the key-learn steps on fader are proportional to the key stroke speed.
- new option in the visible parameter of controls like fader, switches, etc: set the position 'parent Interface builder'.
- new 'Mouse pressed' & "double click" outlets in the Image and Text (comment) modules
- new 'Mouse X' and 'Mouse Y' outlets in the Image module to get the Mouse position on the
- new layouts options in the Interface Builder
- in global Interface navigation bar, you can adjust the number of speed buttons to display.
- new 'Send Midi to Usine' module which sends midi data to Usine itself, exactly like if it was send from an external midi device.
- new inlets in the dashboard module to show the setup or the waveplayer windows.
- midi out module can send codes to different channels at the same time
- new color inlet in the Button module
- vertical scroll enabled in the interface builder
- easy move wire mode in patch
fixed bugs
- the show remote button [R] doesn't work properly
- Timer bug on the navigation bar (touch screen mode)
- various run time errors in the FFT inverse module.
- the VST windows position are now memorized
- many GUI bugs and details solved.
compatibility notes
- the new channel management of the midi out module can cause some backward compatibility problems.
Statistics: Posted by senso — 21 Apr 2009, 15:22
Multi-Core Version
fixed bugs
[4.2 beta 6]
Multi-Core Version
improvements
fixed bugs
[4.2 beta 5]
Multi-Core Version
improvements
fixed bugs
compatibility notes
