ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-04-02T10:35:14+01:00 https://brainmodular.org/forums/app.php/feed/topic/1455 2009-04-02T10:35:14+01:00 2009-04-02T10:35:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=1455&p=8137#p8137 <![CDATA[dry wet gain curve ratio?]]>
dry/wet selector with curves uploaded to addons >audio
Statistics: Posted by gurulogic — 02 Apr 2009, 11:35
2009-04-01T09:56:25+01:00 2009-04-01T09:56:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=1455&p=8113#p8113 <![CDATA[dry wet gain curve ratio?]]>
I could not hear any drop or increase in volume as I moved the cross input between 0 and 1. as an extra check, I also tried inverting one input (-X), and it didn't null 100% when cross was at 0.5, but the sound was a barely audible, faint noise.
What about using the Mapper (Curve) after the fader? You could maybe try to create different curves for different types of effects to compensate for the variations in perceived loudness (or the dB on the meters, if you prefer that).
Statistics: Posted by bsork — 01 Apr 2009, 10:56
2009-04-01T08:47:50+01:00 2009-04-01T08:47:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=1455&p=8112#p8112 <![CDATA[dry wet gain curve ratio?]]> Log does work ok except that most of the fx mix in/dry mix out happens in the last 10-15% of fader travel.
Ideally i would have a 50-50 dry/fx mix when the fader is in the centre position.
Statistics: Posted by gurulogic — 01 Apr 2009, 09:47
2009-04-01T06:19:02+01:00 2009-04-01T06:19:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=1455&p=8110#p8110 <![CDATA[dry wet gain curve ratio?]]> Statistics: Posted by nay-seven — 01 Apr 2009, 07:19
2009-04-01T03:43:27+01:00 2009-04-01T03:43:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=1455&p=8109#p8109 <![CDATA[dry wet gain curve ratio?]]> I have started with a stereo output selctor patch but I am finding the gain curve unacceptable for my use as in there is too much overall gain reduction when the selection fader is in the middle of its travel. The only way I have found to correct this is by changing the centre values in the patch but of course this doesn't allow 100% wet or 100% dry signal.
I need a way to set a gain curve so that I can maintain relatively equal gain throught the travel of the dry wet selection fader.
I also had a look at the Fross Cade patch in the addons section but is seems to have not much better luck for me and some weird gain structure overall.
Any suggestions?
Statistics: Posted by gurulogic — 01 Apr 2009, 04:43
Any suggestions?
