ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-03-16T21:18:37+01:00 https://brainmodular.org/forums/app.php/feed/topic/1425 2009-03-16T21:18:37+01:00 2009-03-16T21:18:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=1425&p=7876#p7876 <![CDATA[usb ports in the set up]]> I tried to solve the pb without success for the moment, but be patient I'll find.
Statistics: Posted by senso — 16 Mar 2009, 21:18
2009-03-16T20:57:14+01:00 2009-03-16T20:57:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=1425&p=7874#p7874 <![CDATA[usb ports in the set up]]>
especially as, if you accidentally open a workspace that's routed to a device (audio or midi) that you didn't turn on the program "forgets" it, you have to turn it off, turn on the hardware, then restart Usine and then re-configure it all over again
Statistics: Posted by runagate — 16 Mar 2009, 20:57
2009-03-16T20:37:50+01:00 2009-03-16T20:37:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=1425&p=7873#p7873 <![CDATA[usb ports in the set up]]>
Either way, it would be nice for usine to 'remember' a device that is not currently plugged in.
+1111
Statistics: Posted by maxdis — 16 Mar 2009, 20:37
2009-03-16T18:34:40+01:00 2009-03-16T18:34:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=1425&p=7867#p7867 <![CDATA[usb ports in the set up]]>
I don't know, could you do something like this with midi-ox?? Since midi-ox is always 'plugged in', usine always recognizes it.
Statistics: Posted by woodslanding — 16 Mar 2009, 18:34
2009-03-16T11:48:18+01:00 2009-03-16T11:48:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1425&p=7862#p7862 <![CDATA[usb ports in the set up]]>
even if global setup verification is one my checklist before any use.
it would be nice if those midi in/midi out entries don't change anytime.
hope it's not a windows limitation.
Statistics: Posted by martignasse — 16 Mar 2009, 11:48
2009-03-16T11:25:49+01:00 2009-03-16T11:25:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=1425&p=7861#p7861 <![CDATA[usb ports in the set up]]> Statistics: Posted by héliouk 6 — 16 Mar 2009, 11:25
+1111
