ArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-03-10T22:00:03+01:00 https://brainmodular.org/forums/app.php/feed/topic/1409 2009-03-10T22:00:03+01:00 2009-03-10T22:00:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=1409&p=7797#p7797 <![CDATA[Some problem with a Preset manager expansion patch]]>
Before someone points out the Conductor to me, I already understand the Conductor functionality but I am looking to have extensive sub patch preset control in conjunction with the Conductor, ie: I am looking to have 128 recallable presets via the preset manager per specific sub patches within 128 master Conductor presets. (one per midi CC value)
I have just tried moving the three preset managers in the 3PM patch to a subpatch and cabling them with data inlets from the dispatch to the sub patch and the behavior is the same so all I can think is that one preset manager must be storing values received at the recall inlets on the other preset managers or else presets recalled with the recall inlets are not seen correctly by the store function. Is this possible?
Statistics: Posted by gurulogic — 10 Mar 2009, 22:00
2009-03-10T21:40:10+01:00 2009-03-10T21:40:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=1409&p=7795#p7795 <![CDATA[Some problem with a Preset manager expansion patch]]>
...but one thing just strike me as a source of your problem: Is the fader or list box stored with the preset? It shouldn't...
Statistics: Posted by bsork — 10 Mar 2009, 21:40
2009-03-10T19:00:10+01:00 2009-03-10T19:00:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=1409&p=7788#p7788 <![CDATA[Some problem with a Preset manager expansion patch]]> Back to the drawing board?
edit:
correction, presets are stored properly on both patches if they are selected via the PM interfaces but not if they are selected by fader or listbox...
Statistics: Posted by gurulogic — 10 Mar 2009, 19:00
2009-03-10T03:16:28+01:00 2009-03-10T03:16:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=1409&p=7782#p7782 <![CDATA[Some problem with a Preset manager expansion patch]]> The idea of this patch is that there are eight X16 preset managers connected to just one listbox and all Storing and clearing is done with only two buttons.
The problem I am having is that the preset managers are not storing in their correct slots. They do however appear to be recalling the correct slots. I have also encountered some internal error messages when clearing slots.
My initial thought was that it would be the Store&Clear Button Router sub patch that was causing the issue, but after deleting it, the behavior was the same even when storing directly from the preset manager UI.
I'm stumped! Any ideas?
http://www.sensomusic.com/forums/upload ... _test5.pat
Statistics: Posted by gurulogic — 10 Mar 2009, 03:16
edit:
