ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-03-23T12:24:08+01:00 https://brainmodular.org/forums/app.php/feed/topic/1404 2009-03-23T12:24:08+01:00 2009-03-23T12:24:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=1404&p=7963#p7963 <![CDATA[arguments on modules]]>
thanks
Statistics: Posted by Gizzeta — 23 Mar 2009, 12:24
2009-03-22T21:15:37+01:00 2009-03-22T21:15:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=1404&p=7952#p7952 <![CDATA[arguments on modules]]> Especially built-in modules like the sampler, etc aren't designed for variable number of parameters.
But if you want to create variable inputs User modules (in C++) I'll see how I can implement it in the sdk, especially a way add a popup window during the GetParameter procedure call and ask the user to chose the number of parameters.
Statistics: Posted by senso — 22 Mar 2009, 21:15
2009-03-22T15:53:59+01:00 2009-03-22T15:53:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=1404&p=7951#p7951 <![CDATA[arguments on modules]]> The user can then provide the arguments that are specified in a function in the module head code, with type(int, float, checkbox, char...), min, max and default. Then the module is create, with appropriate number of imputs and outputs and the needed memory allocation.
It also be useful for argument elaboration requiring hard cpu usage during the creation process.
Statistics: Posted by Gizzeta — 22 Mar 2009, 15:53
2009-03-19T10:51:08+01:00 2009-03-19T10:51:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=1404&p=7913#p7913 <![CDATA[arguments on modules]]>
I'm not sure I understand your request.
You want to add another argument in a module. But where, and when:
- during the drag and drop
- during the creation in the Internal Language Engine
is it with a pupup query, in the module itself as an inlet, etc..?
Statistics: Posted by senso — 19 Mar 2009, 10:51
2009-03-19T01:03:54+01:00 2009-03-19T01:03:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=1404&p=7908#p7908 <![CDATA[arguments on modules]]>
Hi Senso,
thanks for your work!
it would be nice if it was possible to insert one or more arguments in a module.
i.e. to insert "3" for a 3 channel sampler
This would be very usefull for the users modules!!!
what do you think about it? It's hard to do?
Statistics: Posted by Gizzeta — 19 Mar 2009, 01:03
2009-03-06T15:13:02+01:00 2009-03-06T15:13:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=1404&p=7742#p7742 <![CDATA[arguments on modules]]>
Statistics: Posted by Gizzeta — 06 Mar 2009, 15:13
thanks
Hi Senso,
