ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-08-12T16:21:33+01:00 https://brainmodular.org/forums/app.php/feed/topic/1365 2009-08-12T16:21:33+01:00 2009-08-12T16:21:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=9917#p9917 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]> just an idea : try to use a preset manager for each vst and the Conductor (ctrl F7)( via midi ) to control the global presets
maybe this type of patch can help you too :
Statistics: Posted by nay-seven — 12 Aug 2009, 17:21
2009-08-12T15:24:57+01:00 2009-08-12T15:24:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=9915#p9915 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]>
I use a midi footswitch to control a PM which changes presets in either Amplitube 2 or Guitar Rig. Sometimes I use a patch that uses both combined. I would just like the active VST to bring it's UI to the front for viewing and/or editing more easily.
Thx!
Mike
Statistics: Posted by MikeyJ — 12 Aug 2009, 16:24
2009-08-12T14:52:06+01:00 2009-08-12T14:52:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=9914#p9914 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]> this will don't cost anything about cpu
btw , rack is limited to 16 slots...
Statistics: Posted by nay-seven — 12 Aug 2009, 15:52
2009-08-11T08:50:54+01:00 2009-08-11T08:50:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=9907#p9907 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]>
wonder if any1 tried how far this can be taken? i guess the plugin still occupies RAM but (almost) no cpu anymore? and of course the bypass modules (data buses, switches) require some cpu.
say, i'd want to have a plugin rack with hundreds of plugins ready for processing (only 8 active at the same time). i'd imagine it should be possible to get quite far with small plugins (small RAM usage)?
any experiences?
Statistics: Posted by amiga909 — 11 Aug 2009, 09:50
2009-08-11T08:10:22+01:00 2009-08-11T08:10:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=9906#p9906 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]> don't know how you use your preset manager and what you want to do do with , but if your patch is "no active " nothing could work...
so maybe better think for an an other way to do this..?
( maybe i don't understand all...? )
Statistics: Posted by nay-seven — 11 Aug 2009, 09:10
2009-08-11T03:46:37+01:00 2009-08-11T03:46:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=9905#p9905 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]>
I think there may be a problem with interaction with a PM because as soon as I add the Patch Active module the PM stops responding to the midi input from my footswitch. :-)
Mike
Statistics: Posted by MikeyJ — 11 Aug 2009, 04:46
2009-08-10T08:22:01+01:00 2009-08-10T08:22:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=9902#p9902 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]>
second one is for using in the the case you want show the gui of your vst when your track is selected
http://www.sensomusic.com/forums/upload ... lected.jpg
hadn't thought of this one before - cool!
Statistics: Posted by Clearscreen — 10 Aug 2009, 09:22
2009-08-10T08:16:42+01:00 2009-08-10T08:16:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=9901#p9901 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]> first is for using with the "patch active " module
Statistics: Posted by nay-seven — 10 Aug 2009, 09:16
2009-08-10T02:36:00+01:00 2009-08-10T02:36:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=9900#p9900 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]>
Mike
Statistics: Posted by MikeyJ — 10 Aug 2009, 03:36
2009-02-13T23:18:41+01:00 2009-02-13T23:18:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=7518#p7518 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]>
Now if only the position of the VST window was saved with the workspace, it would be absolutely perfect !
Statistics: Posted by FarfadetFarfelu — 13 Feb 2009, 23:18
2009-02-12T23:17:30+01:00 2009-02-12T23:17:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=7505#p7505 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]>
Do I remember correctly when I think that Show Vst used to be a switch that showed the actual status in some earlier versions?
Statistics: Posted by bsork — 12 Feb 2009, 23:17
2009-02-12T23:12:47+01:00 2009-02-12T23:12:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=7504#p7504 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]> Statistics: Posted by nay-seven — 12 Feb 2009, 23:12
2009-02-12T22:54:04+01:00 2009-02-12T22:54:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=7503#p7503 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]> so you have to look for an :
1_ "active on" then "show on"
2_ show off then active off
it's just an abstract idea , i don't have test it....
edit = ok , bsork is nearest...;-)
Statistics: Posted by nay-seven — 12 Feb 2009, 22:54
2009-02-12T22:40:04+01:00 2009-02-12T22:40:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=7502#p7502 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]>
Switch -> Wait One -> Wait One -> Patch Active
Switch -> Has Changed -> Show Vst
There's one thing that can't be made 100% though. That is if you close the VST's GUI while the patch is on, it will pop up when you turn the patch off, and vice versa. I'm not sure I understand what's happening here, but the opposite works ok: Open the GUI while the patch is off and it will follow the status of the switch.
Statistics: Posted by bsork — 12 Feb 2009, 22:40
2009-02-12T18:26:55+01:00 2009-02-12T18:26:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=1365&p=7501#p7501 <![CDATA[How to show a VST plugin UI when a patch is activated ?]]>
I can control the "patch active" module with a switch and the "show VST" with a separate button.
How could i control both the patch active module and show pin of the VSts with just one switch ?
Is there a way to modify a switch so that it acts like a button ?
I tried using "event controls" but i didn't succeed.
Thanks.
Statistics: Posted by FarfadetFarfelu — 12 Feb 2009, 18:26
Thx!
Mike
any experiences?
Mike
Mike
Thanks.
