ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2006-09-04T08:01:23+01:00 https://brainmodular.org/forums/app.php/feed/topic/134 2006-09-04T08:01:23+01:00 2006-09-04T08:01:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=134&p=587#p587 <![CDATA[channels' gain structure]]> contact@sensomusic.com
Statistics: Posted by senso — 04 Sep 2006, 09:01
2006-09-03T22:56:10+01:00 2006-09-03T22:56:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=134&p=586#p586 <![CDATA[channels' gain structure]]> The controlling power is great considering the easy use of midilearn.
I find the interface still a little "dark" as there are many routing connections hidden in several screenshots, but I am habbit to consider that my use of music tools can be a little too specific to dream to find the perfect sw application.
The architecture in itself allows many possibilities, the problem is to visualize it.
If you like, I can send you my setup files for you to check.
let me know and thanks for your costant care.
my best,
luca
Statistics: Posted by unguitar — 03 Sep 2006, 23:56
2006-09-03T17:55:57+01:00 2006-09-03T17:55:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=134&p=585#p585 <![CDATA[channels' gain structure]]> For me, it's important to know how users understand Usine, to improve the software, and be the most clear as possible.
The most important is to communicate each other!
Statistics: Posted by senso — 03 Sep 2006, 18:55
2006-09-03T16:46:46+01:00 2006-09-03T16:46:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=134&p=584#p584 <![CDATA[channels' gain structure]]> The only problem is that I really want to know where I am putting that gain stage as I have also been to bed with my laptop but still she doesn't tell me where is the tricky connection...
I am sorry to disturb with an evident lack of comprehension but this could be the last step to bring my live set up to be based on Usine.
thanks for your time
Statistics: Posted by unguitar — 03 Sep 2006, 17:46
2006-09-03T12:35:50+01:00 2006-09-03T12:35:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=134&p=583#p583 <![CDATA[channels' gain structure]]> It Works without any gain modification. (exactly the same signal from in to out)
Lalo is probably right: do you add the signal from input 1L and 1R together. (the wire from inL goes in the same input module than the wire from inR somewhere in your patch).
I that case the signal is added to itself, and cause a gain modification of +6db?
Statistics: Posted by senso — 03 Sep 2006, 13:35
2006-09-03T11:18:09+01:00 2006-09-03T11:18:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=134&p=582#p582 <![CDATA[channels' gain structure]]>
Example:
guitar signal coming into input 1
U. input 1 feeding U. output 3/4
U. output 3/4 feeding Eventide Orville Spdif in
Eventide Orville Spdif out feeding U. input 3/4.
U. input 3/4 routed to U. Master out.
Master output is U. 7/8.
"U." stands for Usine/audio card
Signal is Unity gain ( O dB) at all stages.
The only place where it shows a different level is on the software output read by Rme mixer, where it is 5/6 dB more than what is fed.
Nice summer game ?
Statistics: Posted by unguitar — 03 Sep 2006, 12:18
2006-09-03T10:54:05+01:00 2006-09-03T10:54:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=134&p=581#p581 <![CDATA[channels' gain structure]]>
the strange fact is that all the tracks show the same level ( I send and distribute 0dB to all the channels) but, even if the hardware levels are all shown the same ( Rme mixer), the software output of Usine shows a boost of approx 5 dB.
I don't want to be hostinate in thinking it is a problem caused by Usine but, believe me, I don't have any boost in the signal chain so the 0 dB coming is should be 0 dB at the output.
No ?
woukdn't just 'cause you are adding several channels at 0db.....the sum will be a little higher :)
Statistics: Posted by lalo — 03 Sep 2006, 11:54
2006-09-03T10:47:06+01:00 2006-09-03T10:47:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=134&p=580#p580 <![CDATA[channels' gain structure]]> Statistics: Posted by senso — 03 Sep 2006, 11:47
2006-09-02T21:12:06+01:00 2006-09-02T21:12:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=134&p=578#p578 <![CDATA[channels' gain structure]]> I don't want to be hostinate in thinking it is a problem caused by Usine but, believe me, I don't have any boost in the signal chain so the 0 dB coming is should be 0 dB at the output.
No ?
Statistics: Posted by unguitar — 02 Sep 2006, 22:12
2006-08-16T10:52:31+01:00 2006-08-16T10:52:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=134&p=542#p542 <![CDATA[channels' gain structure]]> The signal is only copied from the input to the output.
check the input/out gain of the track?
Statistics: Posted by senso — 16 Aug 2006, 11:52
2006-08-15T01:24:26+01:00 2006-08-15T01:24:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=134&p=541#p541 <![CDATA[channels' gain structure]]> I have a signal coming in through a channel and it is sent to an output with nothing in between.
I notice that if I compare the meter's value ( input signal coming into the track with output signal going out) I see the output signal is stronger.
This is causing overloading the output.
It can be easily seen on the tracks in/outs on top right.
The channel output is set to 0dB.
Is there any gain hidden somewhere ?
thanks
Statistics: Posted by unguitar — 15 Aug 2006, 02:24
my best,
luca
Example:
Nice summer game ?
No ?
No ?
thanks
