ArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-01-29T19:28:38+01:00 https://brainmodular.org/forums/app.php/feed/topic/1335 2009-01-29T19:28:38+01:00 2009-01-29T19:28:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=1335&p=7342#p7342 <![CDATA[2 questions]]>
Perhaps you could use redshot drum triggers from DDRum. They are not expensive, and should do the trick for your needs, concerning kick and snare...
I've built a small patch to work with this triggers, and it works fine.
When i will have time, i will try to give you some idea.
Statistics: Posted by ethnix73 — 29 Jan 2009, 19:28
2009-01-29T18:29:12+01:00 2009-01-29T18:29:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=1335&p=7340#p7340 <![CDATA[2 questions]]>
a filter before the trigger input
yeah I tried that, it works better but I get some false triggering yet..the problem is that I have not much room to tweak the filter, because I'm triggering the HiHat and Snare on different frequencies too...so every instrument need to have a definite and almost separate frequency space; so I was hoping there was some Usine module allowing me to get only the first note in a stream, maybe rejecting the remaining notes for a certain time period(user defined): I think it wouldn't be too difficult to create such a patch, but I haven't got any joy still :-(
If you would like the note to hold until the next is triggered, it's a bit more complicated, and it can be achieved in different ways. I haven't got the time right now to create an example, but IIRC I've something similar into the add-on sampling tools/sampler list grouped (see also http://www.sensomusic.com/forums/viewtopic.php?id=1071).
thanks , I've downloaded your patch and will study it later
Statistics: Posted by maxdis — 29 Jan 2009, 18:29
2009-01-29T14:43:52+01:00 2009-01-29T14:43:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=1335&p=7337#p7337 <![CDATA[2 questions]]>
The second problem can be solved in different ways depending on how long your notes are going to sound. The easiest is to have the same length; use the Midi Transformer after the Step Midi and set the gate length there. If you would like the note to hold until the next is triggered, it's a bit more complicated, and it can be achieved in different ways. I haven't got the time right now to create an example, but IIRC I've something similar into the add-on sampling tools/sampler list grouped (see also http://www.sensomusic.com/forums/viewtopic.php?id=1071).
Statistics: Posted by bsork — 29 Jan 2009, 14:43
2009-01-29T13:37:34+01:00 2009-01-29T13:37:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=1335&p=7335#p7335 <![CDATA[2 questions]]> The MIDI note is then sent to the "Next Step" input of a MidiSeq module (connected to a synth VSTi), in order to play the melody...but the MidiSeq output MIDI ON note only, so every note will keep sounding forever; so my second question is: how can I associate a MIDI OFF note to every MIDI ON note sent from the MidiSeq?
thank you
Statistics: Posted by maxdis — 29 Jan 2009, 13:37
thank you
