ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-02-10T14:02:17+01:00 https://brainmodular.org/forums/app.php/feed/topic/1331 2009-02-10T14:02:17+01:00 2009-02-10T14:02:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7472#p7472 <![CDATA[simple A -B toggle buttons]]>
art.
Statistics: Posted by artificial — 10 Feb 2009, 14:02
2009-02-10T13:28:31+01:00 2009-02-10T13:28:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7471#p7471 <![CDATA[simple A -B toggle buttons]]> Statistics: Posted by 23fx23 — 10 Feb 2009, 13:28
2009-02-10T10:33:47+01:00 2009-02-10T10:33:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7470#p7470 <![CDATA[simple A -B toggle buttons]]>
I have a short question:
I have 4 a - b toggle buttons. Furthermore, I have 4 XY-Pads which are laying one upon the other… I would love to do this scenario:
I click on toggle button 1 and the XY-Pad No 1 comes to the fore, when I click on button 2, XY Pad No 2 should be in the foreground (as they are laying one upon the other, there should just be the activated xy-pad visible…) the same for toggle button 3 and 4…
Okay, so, how could I do this??? I mean, the buttons work, but how to get the certain xy-pads to come to the fore???
Thanks guys!!!
Art.
Statistics: Posted by artificial — 10 Feb 2009, 10:33
2009-01-30T01:24:58+01:00 2009-01-30T01:24:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7343#p7343 <![CDATA[simple A -B toggle buttons]]>
hi 23fx23,
do you mean something like this?
http://mfleurent.free.fr/usine/Usine_two_switch.jpg
(B pin of the two OR modules are set to 0)
Hope it help
i've posted a different tab method in the others section that uses this method for switching, but i've used a multi-variable instead of the 'or', 'not' and 'and' logic units. hope it's helpful :)
Statistics: Posted by Clearscreen — 30 Jan 2009, 01:24
2009-01-29T07:25:34+01:00 2009-01-29T07:25:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7334#p7334 <![CDATA[simple A -B toggle buttons]]>
I'm gonna check it out in the afternoon!!
bye and thanks again!! :)
art.
Statistics: Posted by artificial — 29 Jan 2009, 07:25
2009-01-29T00:13:36+01:00 2009-01-29T00:13:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7333#p7333 <![CDATA[simple A -B toggle buttons]]> Image
Ive tried to make with 5 switch:
this might not be the only/best solution but this seems to work well for 2-15 switches.
each switch will output 2-3-4-5-6 to the selector that keep the last pressed switch number and send back to the dispatcher that have "set to 0" enabled, so it will switch off all the others, (add constant 1 on input).ps( I don't use input 1 because it will be the defaut output when switch are off, that's also why it's need to start from 2 , for the selector to select the 2nd , bref...not use 1.) taken from a bsork advice
hope it can be usefull...
Statistics: Posted by 23fx23 — 29 Jan 2009, 00:13
2009-01-28T20:40:52+01:00 2009-01-28T20:40:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7329#p7329 <![CDATA[simple A -B toggle buttons]]>
but i have a question, is it possible to do the same with more switches (5 for example)?? sorta radio buttons or something... ???
thanks in advance :)
art.
Statistics: Posted by artificial — 28 Jan 2009, 20:40
2009-01-28T13:52:58+01:00 2009-01-28T13:52:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7325#p7325 <![CDATA[simple A -B toggle buttons]]>
that's why when a saw your question, i say to myself...it remind me something :)
and here it is
cool this make your day
Statistics: Posted by martignasse — 28 Jan 2009, 13:52
2009-01-28T13:03:39+01:00 2009-01-28T13:03:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7324#p7324 <![CDATA[simple A -B toggle buttons]]> Statistics: Posted by 23fx23 — 28 Jan 2009, 13:03
2009-01-28T12:44:57+01:00 2009-01-28T12:44:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7323#p7323 <![CDATA[simple A -B toggle buttons]]>
Statistics: Posted by nay-seven — 28 Jan 2009, 12:44
2009-01-28T11:01:22+01:00 2009-01-28T11:01:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7318#p7318 <![CDATA[simple A -B toggle buttons]]>
Hope it help
Statistics: Posted by martignasse — 28 Jan 2009, 11:01
2009-01-28T00:59:26+01:00 2009-01-28T00:59:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=1331&p=7310#p7310 <![CDATA[simple A -B toggle buttons]]> when I press A, B shoud go off, if I press B, a should go off, and If I press the active one it should go back to 0.
any idea of how i could do that? It seems a simple thing but im turning around.... if i put inputs that drive the switch then I can't act on them to change,.. should I deal with pannels and separate visual feedback from sending or it s possible do do that with switch
(kind of listbox, but when re-pressing it can turn off)..
Statistics: Posted by 23fx23 — 28 Jan 2009, 00:59
art.
Thanks guys!!!
Art.
hi 23fx23,
Hope it help
art.
art.
and here it is
Hope it help
