ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-01-23T18:13:18+01:00 https://brainmodular.org/forums/app.php/feed/topic/1319 2009-01-23T18:13:18+01:00 2009-01-23T18:13:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1319&p=7249#p7249 <![CDATA[Start and end of a sample]]> thank you Olivier.
Statistics: Posted by cmodica — 23 Jan 2009, 18:13
2009-01-23T17:20:51+01:00 2009-01-23T17:20:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=1319&p=7247#p7247 <![CDATA[Start and end of a sample]]> since the range select is not implemented it's not so easy but not impossible....
Statistics: Posted by senso — 23 Jan 2009, 17:20
2009-01-23T09:37:57+01:00 2009-01-23T09:37:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=1319&p=7242#p7242 <![CDATA[Start and end of a sample]]>
To select the part of a sample to play i had to drag on the left of the wave display window to select the begining (the start point), and after i had to drag on the right of the sample window to select the end point. So now i can for example play in loop just this selected part.
If i can do that in one time by draging the mouse on the part that i need, like to select few lines in a text editor, it will be very faster.
I hope it is more clear ....
Statistics: Posted by cmodica — 23 Jan 2009, 09:37
2009-01-22T18:37:39+01:00 2009-01-22T18:37:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=1319&p=7224#p7224 <![CDATA[Start and end of a sample]]> can you develop?
Statistics: Posted by senso — 22 Jan 2009, 18:37
2009-01-21T10:07:47+01:00 2009-01-21T10:07:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=1319&p=7216#p7216 <![CDATA[Start and end of a sample]]> It will be faster than select start and end in two times.
Statistics: Posted by cmodica — 21 Jan 2009, 10:07
