ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-01-23T21:07:21+01:00 https://brainmodular.org/forums/app.php/feed/topic/1304 2009-01-23T21:07:21+01:00 2009-01-23T21:07:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=1304&p=7252#p7252 <![CDATA[User Curve Don't play on Usine v4.1 beta 8]]>
Senso understand my problem,he will add automatic user curve in futur version, thanks a lot to reply me...
Thanks Again
Statistics: Posted by Simonaki — 23 Jan 2009, 21:07
2009-01-23T18:24:13+01:00 2009-01-23T18:24:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=1304&p=7251#p7251 <![CDATA[User Curve Don't play on Usine v4.1 beta 8]]> Statistics: Posted by senso — 23 Jan 2009, 18:24
2009-01-23T07:14:09+01:00 2009-01-23T07:14:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=1304&p=7240#p7240 <![CDATA[User Curve Don't play on Usine v4.1 beta 8]]> or maybe we can also use this forum :
http://forums.audiofanzine.com/index,id ... usine.html
Statistics: Posted by nay-seven — 23 Jan 2009, 07:14
2009-01-22T23:06:31+01:00 2009-01-22T23:06:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=1304&p=7234#p7234 <![CDATA[User Curve Don't play on Usine v4.1 beta 8]]>
here how i made mine :(beta8)
open sequencer mode , track 1 , add a midifile,click on user1, rename it to " test"
doubleclick on the midifile event to open it , add the module usercurve , choose the the curve "test"
add a "bus "send to audio,data"
route to whatever you want...
Statistics: Posted by nay-seven — 22 Jan 2009, 23:06
2009-01-22T22:22:24+01:00 2009-01-22T22:22:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=1304&p=7232#p7232 <![CDATA[User Curve Don't play on Usine v4.1 beta 8]]> Statistics: Posted by Simonaki — 22 Jan 2009, 22:22
2009-01-20T16:04:27+01:00 2009-01-20T16:04:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=1304&p=7205#p7205 <![CDATA[User Curve Don't play on Usine v4.1 beta 8]]>
Just for the record, I have only the included templates. Have you made your own, maybe?
Statistics: Posted by bsork — 20 Jan 2009, 16:04
2009-01-20T15:11:24+01:00 2009-01-20T15:11:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=1304&p=7203#p7203 <![CDATA[User Curve Don't play on Usine v4.1 beta 8]]> I d'on't have resolved my probleme i'm not crazy, i've try with old version thats work fine but with this new version , no way.
I explain again my problem: when i create usercurve module direct from the cut off's helios for exemple in a empty sub patch on the sequencer i just see " " on the module user curve and user 41 on sequencer and nOT Cut off...so did you have teh same probleme don(t try just a demo ,make yourself a sweety patch for look.
Perhaps i'm making a big stupid mistake of configuration, apologize me for my dirty english
Simon
Statistics: Posted by Simonaki — 20 Jan 2009, 15:11
2009-01-15T19:06:15+01:00 2009-01-15T19:06:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=1304&p=7155#p7155 <![CDATA[User Curve Don't play on Usine v4.1 beta 8]]> i'm not a specialist about this module , so i've load " Demo05 - Sequencer (easy percs) " in the last beta
looking for user curve in the sequencer and all seems ok for me...?
Statistics: Posted by nay-seven — 15 Jan 2009, 19:06
2009-01-15T13:46:27+01:00 2009-01-15T13:46:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=1304&p=7152#p7152 <![CDATA[User Curve Don't play on Usine v4.1 beta 8]]>
i've got a serious problem with User curve module, it doesn't works like when it was the version 4.0. I've try the twice and i'm not crazy
User Curve don't work
Some one as the same probleme or i'm just out of order???
Statistics: Posted by Simonaki — 15 Jan 2009, 13:46
Thanks Again
Simon
