ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-01-18T16:12:56+01:00 https://brainmodular.org/forums/app.php/feed/topic/1271 2009-01-18T16:12:56+01:00 2009-01-18T16:12:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=1271&p=7181#p7181 <![CDATA[Minimal spec]]>
Work perfect !!!!
Just awesome....AWESOME !!!!
Thank you sooo much Nay-seven :) hip hip hourray for you !
I re-discover my synth(Vst) , you can make so weird and cool control with Usine(control filter master with wavetable and lfo in a Synth via XY pad!!! )!
Usine is great! so Great !
Statistics: Posted by fractal — 18 Jan 2009, 16:12
2009-01-18T14:58:27+01:00 2009-01-18T14:58:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=1271&p=7180#p7180 <![CDATA[Minimal spec]]>
here how i see your wish : this way , you have 2 controllers , one for X , an other for Y :
Statistics: Posted by nay-seven — 18 Jan 2009, 14:58
2009-01-18T14:21:44+01:00 2009-01-18T14:21:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=1271&p=7179#p7179 <![CDATA[Minimal spec]]>
Don't work.... i don't know...(in Usine pro all XY pad ; bouncing balls etc etc are ready to use in Midi mode ? )
here a screenshot :
What's wrong?
thank you for help :)
Statistics: Posted by fractal — 18 Jan 2009, 14:21
2009-01-15T14:29:59+01:00 2009-01-15T14:29:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=1271&p=7154#p7154 <![CDATA[Minimal spec]]>
absolutely clear !
I'm a noob on patching some midi module in Usine but i try my best and hope one day i can help like you help me ;)
Statistics: Posted by fractal — 15 Jan 2009, 14:29
2009-01-12T18:53:46+01:00 2009-01-12T18:53:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=1271&p=7079#p7079 <![CDATA[Minimal spec]]>
for the second question : xypad module , to the X outlet , add a multiply module ( maths: a*b ) and use 127 for b
and link this to a data 2 of a " create midi" module ( of course choose "control change" and the number of your midi controller )
link it to a midi out module
do the same for the "Y "outlet
and for finish , add a " has changed " module ( in control events ) between the X outlet and the "create " inlet of the midi create
do the same for the Y...
hope it's clear enought...
Statistics: Posted by nay-seven — 12 Jan 2009, 18:53
2009-01-12T13:51:18+01:00 2009-01-12T13:51:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1271&p=7074#p7074 <![CDATA[Minimal spec]]>
But i have some latency too (i use Usine like a Dream remote for ableton Live)
When i push(click with the mouse for the moment :) ) sometimes i have to click twice and sometime one push is good but with latency...
In the message center of Usine i have sometime in alternance : OUT:?
i have put midi out 1 to midiyoke 1
and midi out 2 to None
maybee this?
Other question, i try to build a X-Y to control my filter in Ableton but i don't know how i have to build this....if you have some example for me(i'm a super noob in building patch, i try my best...)
,thank you ;)
Statistics: Posted by fractal — 12 Jan 2009, 13:51
2009-01-08T07:07:56+01:00 2009-01-08T07:07:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=1271&p=7013#p7013 <![CDATA[Minimal spec]]> for your last question , depending of how you're patching your mute switch but you can add a toggle ( event control) just after your switch..
Statistics: Posted by nay-seven — 08 Jan 2009, 07:07
2009-01-08T04:14:24+01:00 2009-01-08T04:14:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=1271&p=7012#p7012 <![CDATA[Minimal spec]]>
I'm going to wait a little and buy a HP TX2Z ( very comfortable performance,2,4ghz 4gb,multi touch.the dell xt scare me with 1,2ghz...)
I successefuly fighting my computer...via Midiyoke(with my cubes software and monome software...to sync all this mess :what a party!)
And i started create some pretty cool things to control Ableton(synth/sample start totally crazy etc etc... :) )
Definitively a powerful beast, not easy to learn it, but SO POWERFUL !
I can't wait have my tablet i buy the pro version to explore the add-on and the beast
I have a little question... when i create a switch(mute/unmute a track on Ableton Live) i have to Click twice for mute or unmute...is normal or i miss something(well i'm pretty sure ,i miss something :) )
And sorry for my bad english, sometimes one would say i'm like Borat...writing :)
Bye all !!!
Statistics: Posted by fractal — 08 Jan 2009, 04:14
2009-01-05T17:34:52+01:00 2009-01-05T17:34:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=1271&p=6956#p6956 <![CDATA[Minimal spec]]>
sorry for the delay but it's really not easy to answer...
there 's not a good tablet for Usine , but maybe a good one for you...
depends on what you need..maybe depends on your soundcard too
my first impression will be to say 600/700 euros...maybe not enought , cause it's the price of medium normal laptop now...
you talk about an used one , maybe ask to test it with Usine if you can...?
Statistics: Posted by nay-seven — 05 Jan 2009, 17:34
2009-01-05T16:56:04+01:00 2009-01-05T16:56:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=1271&p=6955#p6955 <![CDATA[Minimal spec]]> )
Tant pis...
On verras si ça marche bien avec le Dell xt(vu qu'il gêre le multitouch).
A+
Statistics: Posted by fractal — 05 Jan 2009, 16:56
2009-01-04T21:15:53+01:00 2009-01-04T21:15:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=1271&p=6941#p6941 <![CDATA[Minimal spec]]>
I'm a new "futur" user of Usine pro.
I'm a fan of Reaktor and i think Usine can be wonderful for me (sorry for my crappy english , i'm french and the school is so far now... :) )
I first lookin' for a Lemur (i have a monome 128 and Audiocubes from Percussa, i'm always lookin for a new way to make music.)
But it's a little bit overpriced for me...
And i discover Usine! (i think it's a little bit under exposed, make more videos, with each add-on for example... :) )
First question (but not the last!) :
What good tablet Pc for Usine? the minimal spec/performance (i want use it like a Lemur for Live and make my own control)?
i'm lookin for a Used Dell XT Tablet (650 euros) but 1,2 ghz scare me a little...
Have you some suggestion? my budget(is the good word?) is around 600-700 euros (no problem for used gear/Tablet)
Hope you help me :)
See ya !
Ps here my myspace if you want see some videos/tracks : http://www.myspace.com/fractaldeath
Statistics: Posted by fractal — 04 Jan 2009, 21:15
Work perfect !!!!
here a screenshot :
What's wrong?
absolutely clear !
maybee this?
,thank you ;)
Bye all !!!
Tant pis...
A+
Hope you help me :)
See ya !
