ArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-03-06T17:02:51+01:00 https://brainmodular.org/forums/app.php/feed/topic/1269 2009-03-06T17:02:51+01:00 2009-03-06T17:02:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=1269&p=7744#p7744 <![CDATA[Array - 512 is too small]]> Statistics: Posted by woodslanding — 06 Mar 2009, 17:02
2009-01-09T09:54:00+01:00 2009-01-09T09:54:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=1269&p=7046#p7046 <![CDATA[Array - 512 is too small]]> Statistics: Posted by LevraiBernardo — 09 Jan 2009, 09:54
2009-01-08T08:54:13+01:00 2009-01-08T08:54:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=1269&p=7015#p7015 <![CDATA[Array - 512 is too small]]> I'm thinking about a way to adjust, and increase, this limit in the setup.
Statistics: Posted by senso — 08 Jan 2009, 08:54
2009-01-05T20:11:20+01:00 2009-01-05T20:11:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=1269&p=6960#p6960 <![CDATA[Array - 512 is too small]]>
I wrote my own user module that generate long sequence of values. Its implementation of L-system that return array of values - I'm using it as midi code1 values. L-systems generates sometimes very long streams of values - yes, I can partition it, or send midi values directly from user module, but in this case its nessesery to have it in array outside user module (on array out) so I need to have more than 1 and partition it...
Its in fact not a big problem in implementation but ... not optimal because of unnatural limit of Array module.
Statistics: Posted by nelson — 05 Jan 2009, 20:11
2009-01-05T08:27:25+01:00 2009-01-05T08:27:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=1269&p=6951#p6951 <![CDATA[Array - 512 is too small]]>
As Amiga909 ask: Do you have an example? Not necessarily a code example, but a description of what you want to achieve.
Statistics: Posted by bsork — 05 Jan 2009, 08:27
2009-01-04T20:59:24+01:00 2009-01-04T20:59:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=1269&p=6940#p6940 <![CDATA[Array - 512 is too small]]> Statistics: Posted by nelson — 04 Jan 2009, 20:59
2009-01-04T20:32:30+01:00 2009-01-04T20:32:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=1269&p=6939#p6939 <![CDATA[Array - 512 is too small]]>
why array can have only 512 elements? please, do small revolution in this :) usine should be soft without limits (such a low limits ;)
where? what?
(code example please)
Statistics: Posted by amiga909 — 04 Jan 2009, 20:32
2009-01-04T18:31:41+01:00 2009-01-04T18:31:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=1269&p=6932#p6932 <![CDATA[Array - 512 is too small]]>
Statistics: Posted by nelson — 04 Jan 2009, 18:31
where? what?
