ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2009-09-03T07:24:58+01:00 https://brainmodular.org/forums/app.php/feed/topic/1238 2009-09-03T07:24:58+01:00 2009-09-03T07:24:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=10073#p10073 <![CDATA[manual french translation]]> merci !
Statistics: Posted by nay-seven — 03 Sep 2009, 08:24
2009-09-02T23:03:04+01:00 2009-09-02T23:03:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=10071#p10071 <![CDATA[manual french translation]]>
Statistics: Posted by ethnix73 — 03 Sep 2009, 00:03
2009-06-29T17:10:31+01:00 2009-06-29T17:10:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9549#p9549 <![CDATA[manual french translation]]>
pareil pour le "modules reference "....
ne pas se fier à l'apparence , le document sera bien imprimé sur fond Blanc...;-)
Statistics: Posted by nay-seven — 29 Jun 2009, 18:10
2009-06-29T16:50:12+01:00 2009-06-29T16:50:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9548#p9548 <![CDATA[manual french translation]]>
où est ce qu'on peut télécharger ce manuel en français ?
bravo et merci pour ce beau et long travail
gérald
Statistics: Posted by gercha1 — 29 Jun 2009, 17:50
2009-06-29T12:55:41+01:00 2009-06-29T12:55:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9545#p9545 <![CDATA[manual french translation]]> Bravo et merci beaucoup.
Statistics: Posted by Plaf — 29 Jun 2009, 13:55
2009-06-20T17:39:31+01:00 2009-06-20T17:39:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9459#p9459 <![CDATA[manual french translation]]> Statistics: Posted by 23fx23 — 20 Jun 2009, 18:39
2009-06-20T17:29:42+01:00 2009-06-20T17:29:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9458#p9458 <![CDATA[manual french translation]]>
Statistics: Posted by nay-seven — 20 Jun 2009, 18:29
2009-06-20T16:47:20+01:00 2009-06-20T16:47:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9457#p9457 <![CDATA[manual french translation]]> Statistics: Posted by 23fx23 — 20 Jun 2009, 17:47
2009-06-20T10:47:48+01:00 2009-06-20T10:47:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9455#p9455 <![CDATA[manual french translation]]> ) du truc
peut être rajouter ( dans le A and B par exemple ) :
lire verticalement , exemple ici : si A=1 et B = 1 alors sortie = 1
Statistics: Posted by nay-seven — 20 Jun 2009, 11:47
2009-06-19T23:08:52+01:00 2009-06-19T23:08:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9451#p9451 <![CDATA[manual french translation]]> c vrai pour les logical, j'ai tenté un truc, je pense c déja mieux..
Statistics: Posted by 23fx23 — 20 Jun 2009, 00:08
2009-06-19T22:46:39+01:00 2009-06-19T22:46:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9449#p9449 <![CDATA[manual french translation]]> les explications 0 1 sont sur une seule ligne ( ou alors ça vient de chez moi..? ) et du coup ça ne veut rien dire...
regarder dans le browser d'usine et faite " show info " vous aurez la bonne disposition..
ou alors on fait un screenshot...
Statistics: Posted by nay-seven — 19 Jun 2009, 23:46
2009-06-19T21:29:13+01:00 2009-06-19T21:29:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9448#p9448 <![CDATA[manual french translation]]> version anglaise et fancaise pour le module array:
La valeur de réinitialisation est appliquée quand le bouton reset est pressé ou quand l'utilisateur effectue un [shift+click] sur le panneau.
ce n'est pas plutot (ctrl) click pour le reset...?
Statistics: Posted by nay-seven — 19 Jun 2009, 22:29
2009-06-19T20:10:18+01:00 2009-06-19T20:10:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9447#p9447 <![CDATA[manual french translation]]>
sinon
relecture faite jusqu'à "Modules de contrôle de l'interface (Interface control)"
je vais manger un morceau..
sinon, j'ai mis de petits jpg pour les log et exp ( en doutant de moi car je trouve des résultats inverses sur le web..donc à vérifier senso...
@ethnix sinon, j'ai traduit le trace value :
en gros ce module envoie n'importe quelles suite de données dans la console d'usine
exemple , tu relie un modules line , tu dessine une courbe et tu fait play , ensuite tu ouvre la console et cela te permets de faire un copier coller de ces valeurs..
dis moi si c'est pas clair..;-)
Statistics: Posted by nay-seven — 19 Jun 2009, 21:10
2009-06-19T18:39:49+01:00 2009-06-19T18:39:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9444#p9444 <![CDATA[manual french translation]]>
scroll noun rouleau m. scroll down:
~ down (person) faire défiler de haut en bas;
~ down [sth] faire défiler [qch] de haut en bas (document).
scroll up:
~ up (person) faire défiler de bas en haut;
~ up [sth] faire défiler [qch] de bas en haut (document).
'TO SCROLL' found in these entries:
French:
défiler
Statistics: Posted by grabbs — 19 Jun 2009, 19:39
2009-06-19T18:16:20+01:00 2009-06-19T18:16:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9442#p9442 <![CDATA[manual french translation]]> Statistics: Posted by ethnix73 — 19 Jun 2009, 19:16
2009-06-19T18:00:10+01:00 2009-06-19T18:00:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9441#p9441 <![CDATA[manual french translation]]> "La valeur numérique grandit doucement sur le coté gauche, et de plus en plus vite vers le coté droit."
je pensais que l'on pourrai remplacer " coté gauche " par "début de la courbe " et fin de la courbe , ,comme ça on reste dans l'idée de temps...?..
quitte à mettre un petit jpg...?
Statistics: Posted by nay-seven — 19 Jun 2009, 19:00
2009-06-19T17:12:08+01:00 2009-06-19T17:12:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9439#p9439 <![CDATA[manual french translation]]>
Statistics: Posted by nay-seven — 19 Jun 2009, 18:12
2009-06-19T14:19:18+01:00 2009-06-19T14:19:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9438#p9438 <![CDATA[manual french translation]]>
il semble aussi qu'il y ai des modules qui ont disparus, remplacé depuis (pich tracker), ya aussi des nouveaux (roll array),
que je n'ai pas implementé, peut etre d'abord on recheck se qui à été fait et on fait un point.
bien joué etnix, g vu le temps que ça prenais et t'a abattu une vraiment grosse masse de taf à toi tout seul, mais tu doit etre un expert maintenant :)
martignasse: chelou g un mess qu'a disparu, jte remerciais toi et senso pour cette 4.22 excellente..
edit oops jplane il a pas été supp.. :)
Statistics: Posted by 23fx23 — 19 Jun 2009, 15:19
2009-06-19T12:10:46+01:00 2009-06-19T12:10:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9437#p9437 <![CDATA[manual french translation]]>
Je pense qu'il faudrait vérifier les liens HTML. Je les ai modifiés dans les dernières traductions uniquement (à partir d'interface design). Apparemment, dans le manuel c'est fait...
Une petite question:
1) Peut on modifier le panneau Main Wiki pages, afin que les liens pointent directement sur les traductions éffectués; plutot que de devoir cliquer sur "fr" à chaque fois?
Maintenant, il restera à traduire les légendes des images...
Souvent, j'ai mis lenom en anglais entre parenthèse. En effet, si Usine reste en anglais, je pense qu'il n'y a pas d'intérêt à tout traduire.
Statistics: Posted by ethnix73 — 19 Jun 2009, 13:10
2009-06-19T02:49:56+01:00 2009-06-19T02:49:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9433#p9433 <![CDATA[manual french translation]]> bon normalement analyse terminée, reste a rechecker g pas encore relu.
martignasse: faut b1 vous remercier pour ce que vous avez fait avec senso , vraiment excellente cette 4.22.
Statistics: Posted by 23fx23 — 19 Jun 2009, 03:49
2009-06-18T22:26:07+01:00 2009-06-18T22:26:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9430#p9430 <![CDATA[manual french translation]]>
Statistics: Posted by ethnix73 — 18 Jun 2009, 23:26
2009-06-18T22:11:29+01:00 2009-06-18T22:11:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9429#p9429 <![CDATA[manual french translation]]> Statistics: Posted by 23fx23 — 18 Jun 2009, 23:11
2009-06-18T21:15:17+01:00 2009-06-18T21:15:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9428#p9428 <![CDATA[manual french translation]]> ok pour finesse
Statistics: Posted by ethnix73 — 18 Jun 2009, 22:15
2009-06-18T20:38:54+01:00 2009-06-18T20:38:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9426#p9426 <![CDATA[manual french translation]]>
chapeau bas, vous assurez un max :cool:
Statistics: Posted by martignasse — 18 Jun 2009, 21:38
2009-06-18T20:11:18+01:00 2009-06-18T20:11:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1238&p=9425#p9425 <![CDATA[manual french translation]]> on efface..?
sinon, pour "sharpness" je propose " finesse"..?
relecture faite pour :
audio
data
midi
Statistics: Posted by nay-seven — 18 Jun 2009, 21:11
gérald
sinon
scroll up:
French:
défiler
audio
data
midi
