ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-03-08T19:11:00+01:00https://brainmodular.org/forums/app.php/feed/topic/12302010-03-08T19:11:00+01:002010-03-08T19:11:00+01:00https://brainmodular.org/forums/viewtopic.php?t=1230&p=12414#p12414i try to find myself a solution,
and thanks for usinome lite, i try it just now !!! nice tool !!
gercha1
Statistics: Posted by gercha1 — 08 Mar 2010, 19:11
]]>2010-03-08T18:47:11+01:002010-03-08T18:47:11+01:00https://brainmodular.org/forums/viewtopic.php?t=1230&p=12413#p12413about latency , i can't do more , depending of windows , the joystick, your computer and so.... sorry again
Statistics: Posted by nay-seven — 08 Mar 2010, 18:47
]]>2010-03-08T17:26:41+01:002010-03-08T17:26:41+01:00https://brainmodular.org/forums/viewtopic.php?t=1230&p=12412#p12412 I try your joystick patch with a dance pad i got a lot of latency what are you mean with the patch "more sensitive " ? thank in advance gercha
Statistics: Posted by gercha1 — 08 Mar 2010, 17:26
]]>2008-12-25T20:04:38+01:002008-12-25T20:04:38+01:00https://brainmodular.org/forums/viewtopic.php?t=1230&p=6705#p6705Statistics: Posted by héliouk 6 — 25 Dec 2008, 20:04
2008-12-23T17:01:23+01:002008-12-23T17:01:23+01:00https://brainmodular.org/forums/viewtopic.php?t=1230&p=6664#p6664add 3 axis , Z-rotation, 2 direction pad , 2 sliders, and 16 buttons support must be compatible with most of gamepad and big joystick ..
Joystick Selector - Selects which joystick to assign ( up to 8 )
Deadzone % - Size of non-responsive zone at dead center of X-Y axes,as a % of total range (0 to 50%).
Smoothness - Higher values give smoother response, at the cost of a small amount of latency. Range: 1 - 5.
button 1 and 2 have a switch option ( easy to copy to other buttons..)
enjoy
(updated )
Statistics: Posted by nay-seven — 23 Dec 2008, 17:01
]]>BrainModularBrainModular Users Forum2010-03-08T19:11:00+01:00https://brainmodular.org/forums/app.php/feed/topic/12302010-03-08T19:11:00+01:002010-03-08T19:11:00+01:00https://brainmodular.org/forums/viewtopic.php?t=1230&p=12414#p12414i try to find myself a solution,
gercha1
]]>2008-12-23T17:01:23+01:002008-12-23T17:01:23+01:00https://brainmodular.org/forums/viewtopic.php?t=1230&p=6664#p6664add 3 axis , Z-rotation, 2 direction pad , 2 sliders, and 16 buttons support must be compatible with most of gamepad and big joystick ..
enjoy
(updated )
