ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-11-15T13:37:13+01:00 https://brainmodular.org/forums/app.php/feed/topic/1141 2008-11-15T13:37:13+01:00 2008-11-15T13:37:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=1141&p=6259#p6259 <![CDATA[Storing a toggle module status with the conductor]]>
Statistics: Posted by La Tenaille — 15 Nov 2008, 13:37
2008-11-12T19:10:45+01:00 2008-11-12T19:10:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=1141&p=6226#p6226 <![CDATA[Storing a toggle module status with the conductor]]> make a midi learn on a switch with the 'toggle' option activated (right click)
Statistics: Posted by senso — 12 Nov 2008, 19:10
2008-11-12T17:22:29+01:00 2008-11-12T17:22:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=1141&p=6221#p6221 <![CDATA[Storing a toggle module status with the conductor]]> I don't know how to use these modules... I've tried empirically, but nothing concrete happens in my poor brain ;)
My need is quite simple: I've affected a MIDI pedal board switch to make it toggle a toggle module (the toggle state changes each time I press my pedal board switch), and I need to store this toggle initial position with the conductor. I'm also a bit stuck because I feel possible conflicts between the switch and the MIDI message...
Please keep in mind I don't know maths, and thank you for your patience!
Jacques
Statistics: Posted by La Tenaille — 12 Nov 2008, 17:22
2008-11-10T18:55:54+01:00 2008-11-10T18:55:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=1141&p=6194#p6194 <![CDATA[Storing a toggle module status with the conductor]]> you have to create your own toggle.
- a switch
- a math/variable
a math/logical/not
Statistics: Posted by senso — 10 Nov 2008, 18:55
2008-11-09T17:52:01+01:00 2008-11-09T17:52:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1141&p=6176#p6176 <![CDATA[Storing a toggle module status with the conductor]]> How I can I do that?
Statistics: Posted by La Tenaille — 09 Nov 2008, 17:52
Jacques
- a switch
- a math/variable
a math/logical/not
