ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-10-28T17:37:39+01:00 https://brainmodular.org/forums/app.php/feed/topic/1104 2008-10-28T17:37:39+01:00 2008-10-28T17:37:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=1104&p=5957#p5957 <![CDATA[Hiding pins of a sub patch]]>
hope it help.
It does! Thanks for the explanations
Statistics: Posted by La Tenaille — 28 Oct 2008, 17:37
2008-10-28T17:35:01+01:00 2008-10-28T17:35:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1104&p=5956#p5956 <![CDATA[Hiding pins of a sub patch]]>
Is it possible to create a text / fader / switch combo in a sub patch without having the corresponding pin created in the main sub-patch combo?
The only solution i see is to "encapsulate" you'r text / fader / switch combo in one more subpatch to prevent him to be on the pin list.
I also consider it a bug that the pins move around on a sub-patch, but the cables outside it do not. It seems connections are being referenced by pin number only--not by name or value.
I asked senso about that some time ago (http://www.sensomusic.com/forums/viewtopic.php?id=572). I seems hard to fix.
Also I have subpatchs that I cannot get the pins in the desired order, no matter where I move the objects inside the patch. Certain pins insist on staying in certain positions, regardless of where they are internally.
on subpatch, pins order is complex. before all, there is at least 4 categories of pins :
- audio in/out, are on top,
- data input/output come after,
- midi in/out,
-and last, all interface modules in the patch (sliders, switch...).
inside these categories, pins are ordered by the position of the module.
for example, if you put a slider on top of a data input, the slider pin will below the data input pin on the subpatch.
hope it help.
Statistics: Posted by martignasse — 28 Oct 2008, 17:35
2008-10-28T16:57:07+01:00 2008-10-28T16:57:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=1104&p=5954#p5954 <![CDATA[Hiding pins of a sub patch]]> It seems we're working the same way and having the same troubles at the same time!
I'm also fighting against those wild moving pins ;)
Statistics: Posted by La Tenaille — 28 Oct 2008, 16:57
2008-10-28T16:52:23+01:00 2008-10-28T16:52:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=1104&p=5953#p5953 <![CDATA[Hiding pins of a sub patch]]>
Also I have subpatches that I cannot get the pins in the desired order, no matter where I move the objects inside the patch. Certain pins insist on staying in certain positions, regardless of where they are internally.
well, that's all my subpatch complaints for today ;)
Statistics: Posted by woodslanding — 28 Oct 2008, 16:52
2008-10-28T16:45:04+01:00 2008-10-28T16:45:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=1104&p=5951#p5951 <![CDATA[Hiding pins of a sub patch]]> Is it possible to create a text / fader / switch combo in a sub patch without having the corresponding pin created in the main sub-patch combo?
Statistics: Posted by La Tenaille — 28 Oct 2008, 16:45
hope it help.
- midi in/out,
hope it help.
