ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-10-31T06:28:18+01:00 https://brainmodular.org/forums/app.php/feed/topic/1100 2008-10-31T06:28:18+01:00 2008-10-31T06:28:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=6027#p6027 <![CDATA[2 more scripts: transpose+multiply]]>
Statistics: Posted by bsork — 31 Oct 2008, 06:28
2008-10-31T05:08:15+01:00 2008-10-31T05:08:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=6025#p6025 <![CDATA[2 more scripts: transpose+multiply]]> probably not bug-free its good fun.
here a mp3 example
www.thaumat.org/_permShare/mp3/mep.dry.mp3
www.thaumat.org/_permShare/mp3/mep.wet.mp3
pretty weird ;)
Statistics: Posted by amiga909 — 31 Oct 2008, 05:08
2008-10-30T12:01:13+01:00 2008-10-30T12:01:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=6014#p6014 <![CDATA[2 more scripts: transpose+multiply]]>
Moody.
Statistics: Posted by moody33 — 30 Oct 2008, 12:01
2008-10-30T08:32:12+01:00 2008-10-30T08:32:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=6003#p6003 <![CDATA[2 more scripts: transpose+multiply]]> Anyway, I don't think this patch is very useful for very small ranges anyway - after all it's about transposing and thus "enlarging" the playable range.
@amiga909: You can restrict ranges and transpose without a script, but as you mention hanging notes are a problem if parameters are changed between NoteOn and NoteOff. I guess there are ways of getting the exact same behaviour as the various incarnations of the transpose script using only modules, but it wouldn't be easy, and I suspect that the result would end up as rather more complex to customize or debug than what is essentially a quite simple script.
Usine patching is as we all know very much about creating data flows, but the inherent problem of MIDI notes is that they consist of two essentialy non-related messages, so the NoteOff has to refer back to something earlier on in the flow one way or another, which can be tricky.
Statistics: Posted by bsork — 30 Oct 2008, 08:32
2008-10-30T05:12:55+01:00 2008-10-30T05:12:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=6001#p6001 <![CDATA[2 more scripts: transpose+multiply]]> this little experiment patch here does not allow to change low and hi limits in real time (because of hanging notes problem).
further its not rescaled as moody specified.
Statistics: Posted by amiga909 — 30 Oct 2008, 05:12
2008-10-30T01:09:26+01:00 2008-10-30T01:09:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5998#p5998 <![CDATA[2 more scripts: transpose+multiply]]> I've test it a bit and It seems to works very well.
I've notice only one thing, but it's normal and totally logical : if the range is below one octave, the script don't take care and modulate within a range of one or two octave around the specified range. It's logical and I'm happy to see that the script don't give strange results in this case. Really great script . It solved my problem so far! Perfect !
Finally, you're a genius !
Statistics: Posted by moody33 — 30 Oct 2008, 01:09
2008-10-29T23:20:57+01:00 2008-10-29T23:20:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5995#p5995 <![CDATA[2 more scripts: transpose+multiply]]>
This time I've done some testing, and seems ok to me, but the behaviour of the octave foldback together with the extra restriction of what notes to output can be somewhat confusing the first time it's encountered, I guess...
Try it and let me hear your comments!
Statistics: Posted by bsork — 29 Oct 2008, 23:20
2008-10-29T12:22:52+01:00 2008-10-29T12:22:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5987#p5987 <![CDATA[2 more scripts: transpose+multiply]]> Statistics: Posted by moody33 — 29 Oct 2008, 12:22
2008-10-29T12:12:42+01:00 2008-10-29T12:12:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5986#p5986 <![CDATA[2 more scripts: transpose+multiply]]>
Could you have another go at it ?
Statistics: Posted by bsork — 29 Oct 2008, 12:12
2008-10-29T11:52:48+01:00 2008-10-29T11:52:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5985#p5985 <![CDATA[2 more scripts: transpose+multiply]]> Statistics: Posted by moody33 — 29 Oct 2008, 11:52
2008-10-29T11:50:12+01:00 2008-10-29T11:50:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5984#p5984 <![CDATA[2 more scripts: transpose+multiply]]> Statistics: Posted by bsork — 29 Oct 2008, 11:50
2008-10-29T11:45:33+01:00 2008-10-29T11:45:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5983#p5983 <![CDATA[2 more scripts: transpose+multiply]]> Thanks you again.
Statistics: Posted by moody33 — 29 Oct 2008, 11:45
2008-10-29T11:34:59+01:00 2008-10-29T11:34:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5982#p5982 <![CDATA[2 more scripts: transpose+multiply]]> Thanks you very much .
I'll take a look today.
Statistics: Posted by moody33 — 29 Oct 2008, 11:34
2008-10-29T10:56:45+01:00 2008-10-29T10:56:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5981#p5981 <![CDATA[2 more scripts: transpose+multiply]]>
I ended up using slighty different math than what I outlined above. Mind you, the patch is NOT TESTED AT ALL, but the script compiles. I don't think I will have any time for testing it myself before tomorrow nigth, so if you can download it and test it for me that would be fine.
Of course, if anyone else want to have a go at it - please do!
Statistics: Posted by bsork — 29 Oct 2008, 10:56
2008-10-28T22:35:12+01:00 2008-10-28T22:35:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5973#p5973 <![CDATA[2 more scripts: transpose+multiply]]>
As for your request, I don't feel like a genius, but I'll see what I can do (unless - as always - someone else is quicker than me).
Statistics: Posted by bsork — 28 Oct 2008, 22:35
2008-10-28T17:44:06+01:00 2008-10-28T17:44:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5958#p5958 <![CDATA[2 more scripts: transpose+multiply]]>
Very interesting topic !
I had try some month ago to build a patch that keep note on/off into a specific range, even if the midi input range is out off this range, without great success. As I don't understand english very well, I have to ask you some question related to this topic.
- What means Wrap around? I don't understand this function.
- I think that bsork answer to my desire patch ( keep note on/off into a specific range ) with this comment :
X > 127: 127 - 11 + ((X -128) MOD 12)
X < 0: ABS((12 + X) MOD 12)
But where I have to copy this in a script?
If you have the time could you show me how to do a simple script with the following features:
- 2 input to specify the lower and higher notes . If the input is below or above this range, midi ouput is modulate. For example, i want a range between note number 36 and 60. If the input note is above 60 , the ouput have to stay between 48 (60-12=48) and 60. If the input is lower than note 36, then, the output have to stay between 36 and 48 (36+12=48)
- In also need an option that let choose if the modulator is engage or not. For example, always with a range of 36 to 60, I don't want notes below note number 30 takes in consideration. I want them ignored ( note 31 is modulated, but note 25 is ignored) So the idea is a second range input ( low and high) that specified a range of notes ( below or above the first range selector) to be ignored.
I'm really sorry for my bad english. I wish you understand my request, and I hope that a genius can create this script cause I've not good results with patching and I really understand nothing to scripting.
Thanks you in advance.
Statistics: Posted by moody33 — 28 Oct 2008, 17:44
2008-10-28T07:09:10+01:00 2008-10-28T07:09:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5937#p5937 <![CDATA[2 more scripts: transpose+multiply]]>
I would probably implement it within the range of the piano keyboard, rather than 0 to 127.
Statistics: Posted by woodslanding — 28 Oct 2008, 07:09
2008-10-27T13:15:26+01:00 2008-10-27T13:15:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5929#p5929 <![CDATA[2 more scripts: transpose+multiply]]>
Just a bit too lazy to upload a complete script right now... :)
Statistics: Posted by bsork — 27 Oct 2008, 13:15
2008-10-27T11:01:10+01:00 2008-10-27T11:01:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5927#p5927 <![CDATA[2 more scripts: transpose+multiply]]> there was an error in the 2nd script: noteOff detection asked for tmp.data2 instead of tmp.msg
more (hopefully some day bug-free) scripts to follow
.. thinking about a patch that ressembles a yamaha mep-4 (+ a note closer)
used to have fun with this 4xIn/4xOut midi processor from 1986.
Statistics: Posted by amiga909 — 27 Oct 2008, 11:01
2008-10-27T08:55:46+01:00 2008-10-27T08:55:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5921#p5921 <![CDATA[2 more scripts: transpose+multiply]]> Statistics: Posted by senso — 27 Oct 2008, 08:55
2008-10-26T21:22:57+01:00 2008-10-26T21:22:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=1100&p=5913#p5913 <![CDATA[2 more scripts: transpose+multiply]]> - midi note transpose with wrap around option
- midi note multiply with wrap around option
tkx for the note closer script in the addon section, btw :)
CODE:
//////////////////////////////////////////////////////// transpose midi note// 2008-10-24&#58; @bSork, first version // 2008-10-26&#58; @amiga909, 'wrap around' added //////////////////////////////////////////////////////VAR pIn, pOut, pTransp, pWrapAround &#58; tParameter;TYPE tTransp = ARRAY OF integer;VAR transp &#58; ARRAY OF tTransp;VAR tmp &#58; tMidi;VAR len, transpose, i, tempTransp &#58; integer;PROCEDURE Init;BEGIN   pIn &#58;= CreateParam&#40;'midi in', ptMidi&#41;; SetIsOutput&#40;pIn, FALSE&#41;;   pOut &#58;= CreateParam&#40;'midi out', ptMidi&#41;; SetIsInput&#40;pOut, FALSE&#41;;   pTransp &#58;= CreateParam&#40;'transpose', ptDataFader&#41;; SetIsOutput&#40;pTransp, FALSE&#41;;   SetFormat&#40;pTransp, '%.0f'&#41;; SetMin&#40;pTransp, -127&#41;; SetMax&#40;pTransp, 127&#41;;   pWrapAround &#58;= CreateParam&#40;'wrap around', ptSwitch&#41;; SetIsOutput&#40;pWrapAround, FALSE&#41;;   SetArrayLength&#40;transp, 16&#41;;   FOR i &#58;= 0 TO 15 DO // A two-dimensional array; &#91;16 channels&#93;&#91;128 transpose values&#93;      SetArrayLength&#40;transp&#91;i&#93;, 128&#41;;END; // expects a noteOn msg with velocity > 0; outputs the transposed note value &#91;0-127&#93;FUNCTION calcTranspose &#40;t&#58; integer; wrap&#58; single&#41;&#58; integer;BEGIN IF wrap > 0 THEN BEGIN //     IF t > 127 THEN         result &#58;= t - 128    ELSE IF t < 0 THEN         result &#58;= t + 128;   END ELSE BEGIN    IF t > 127 THEN         result&#58;= 127    ELSE IF t < 0 THEN         result&#58;=0    ELSE          result&#58;=t;  END;  END;// mainBEGIN   len &#58;= GetLength&#40;pIn&#41;;   IF &#40;len > 0&#41;  THEN BEGIN      transpose &#58;= trunc&#40;GetValue&#40;pTransp&#41;&#41;;      SetLength&#40;pOut, len&#41;;      FOR i &#58;= 0 TO &#40;len - 1&#41; DO BEGIN         GetMidiArrayValue&#40;pIn, i, tmp&#41;;          tempTransp &#58;= transpose + tmp.data1;          IF  &#40;tmp.msg = 144&#41; AND &#40;tmp.data2 > 0&#41; THEN BEGIN // NoteOn             tempTransp&#58;= calcTranspose&#40;tempTransp, GetValue&#40;pWrapAround&#41;&#41;;             transp&#91;tmp.channel - 1&#93;&#91;tmp.data1&#93; &#58;= tempTransp;             tmp.data1 &#58;= tempTransp;               SetMidiArrayValue&#40;pOut, i, tmp&#41;;         END         ELSE IF &#40;tmp.msg = 128&#41; or &#40;&#40;tmp.msg = 144&#41; and &#40;tmp.data2 = 0&#41;&#41; THEN // NoteOff             tmp.data1 &#58;= transp&#91;tmp.channel - 1&#93;&#91;tmp.data1&#93;;               SetMidiArrayValue&#40;pOut, i, tmp&#41;;         END;     END   ELSE BEGIN      SetLength&#40;pOut, 0&#41;;   END;END.
CODE:
//////////////////////////////////////////////////////// multiply midi note// 2008-10-24&#58; @bSork, first version of midi transpose// 2008-10-26&#58; @amiga909, midi multiply//////////////////////////////////////////////////////VAR pIn, pOut, pMult, pWrapAround &#58; tParameter;TYPE tMult = ARRAY OF integer;VAR mult &#58; ARRAY OF tMult;VAR tmp &#58; tMidi;VAR len, i, tempMult &#58; integer;VAR multiply&#58; double;PROCEDURE Init;BEGIN   pIn &#58;= CreateParam&#40;'midi in', ptMidi&#41;; SetIsOutput&#40;pIn, FALSE&#41;;   pOut &#58;= CreateParam&#40;'midi out', ptMidi&#41;; SetIsInput&#40;pOut, FALSE&#41;;   pMult &#58;= CreateParam&#40;'multiply', ptDataFader&#41;; SetIsOutput&#40;pMult, FALSE&#41;;   SetMin&#40;pMult, 0.125&#41;; SetMax&#40;pMult, 8&#41;; SetDefaultValue&#40;pMult,1&#41;;   pWrapAround &#58;= CreateParam&#40;'wrap around', ptSwitch&#41;; SetIsOutput&#40;pWrapAround, FALSE&#41;;   SetArrayLength&#40;mult, 16&#41;;   FOR i &#58;= 0 TO 15 DO // A two-dimensional array; &#91;16 channels&#93;&#91;128 multiply values&#93;      SetArrayLength&#40;mult&#91;i&#93;, 128&#41;;END; // expects a noteOn msg with velocity > 0; outputs the multiplyd note value &#91;0-127&#93;FUNCTION calcMultiply &#40;t&#58; integer; wrap&#58; single&#41;&#58; integer; var tt&#58;integer;BEGIN IF wrap > 0 THEN BEGIN    tt&#58;= 128*&#40;trunc&#40;t/128&#41;&#41;;     IF t > 127 THEN         result &#58;= t - tt    ELSE IF t < 0 THEN         result &#58;= t + tt;  END ELSE BEGIN    IF t > 127 THEN         result&#58;= 127    ELSE IF t < 0 THEN         result&#58;=0    ELSE          result&#58;=t;  END;  END;// mainBEGIN   len &#58;= GetLength&#40;pIn&#41;;   IF &#40;len > 0&#41;  THEN BEGIN      multiply &#58;= &#40;GetValue&#40;pMult&#41;&#41;;      SetLength&#40;pOut, len&#41;;      FOR i &#58;= 0 TO &#40;len - 1&#41; DO BEGIN         GetMidiArrayValue&#40;pIn, i, tmp&#41;;          tempMult &#58;= round &#40;multiply * tmp.data1&#41;;          IF  &#40;tmp.msg = 144&#41; AND &#40;tmp.data2 > 0&#41; THEN BEGIN // NoteOn             tempMult&#58;= calcMultiply&#40;tempMult, GetValue&#40;pWrapAround&#41;&#41;;             mult&#91;tmp.channel - 1&#93;&#91;tmp.data1&#93; &#58;= tempMult;             tmp.data1 &#58;= tempMult;               SetMidiArrayValue&#40;pOut, i, tmp&#41;;         END         ELSE IF &#40;tmp.msg = 128&#41; or &#40;&#40;tmp.msg = 144&#41; and &#40;tmp.data2 = 0&#41;&#41; THEN // NoteOff             tmp.data1 &#58;= mult&#91;tmp.channel - 1&#93;&#91;tmp.data1&#93;;               SetMidiArrayValue&#40;pOut, i, tmp&#41;;         END;     END   ELSE BEGIN      SetLength&#40;pOut, 0&#41;;   END;END.
Statistics: Posted by amiga909 — 26 Oct 2008, 21:22
here a mp3 example
pretty weird ;)
Moody.
CODE:
CODE:
