ArrayArray
BrainModularBrainModular Users Forum2008-10-25T19:45:30+01:00https://brainmodular.org/forums/app.php/feed/topic/10972008-10-25T19:45:30+01:002008-10-25T19:45:30+01:00https://brainmodular.org/forums/viewtopic.php?t=1097&p=5898#p5898Statistics: Posted by antwan — 25 Oct 2008, 20:45
2008-10-25T15:49:02+01:002008-10-25T15:49:02+01:00https://brainmodular.org/forums/viewtopic.php?t=1097&p=5896#p5896[4.0 beta 13] improvements - midi & key learn allowed in patches of the sequencer!
fixed bugs - the aux send on/off now appears in the global remote - a blank remote panel when the patch selection changes in the grid - an array input can't have a zero length in scripts - the Rack mode listbox popup menu is greyed - compatibility problems of presets saved with older versions
[4.0 beta 12] improvements - new aux send on/off switch in the track out mixer - the sequenced step, lines, point, switches duration goes now up to 10,000 seconds - all string inlets in Usine can now be manipulated in real time - new preset x16 module fixed bugs - various small display bugs in the Interface builder - the Destroy export procedure missing in User Modules examples - right click midilearn popup is now more contextual... - aux send order problems in the track out mixer - bad wavedisplay/pitch+gain & wavedisplay/pitch+gain+speed subpatches initialisation - moving muti-selected patches in the sequencer is tricky. - small bugs in the preset storage in sub-patches
[4.0 beta 11] fixed bugs - double click problems on the navigation bar (touch-screen mode) - local host monitoring (OSC) now works (new option in OSC setup)
[4.0 beta 10][/b fixed bugs - wrong Data/Counter with Max sub patch in the module library - bad object selection in the interface builder - various details
[4.0 beta 9] fixed bugs - bad multi copy of patches in the sequencer timeline. - better velocity adjustment in the pianoroll - better snap to grid of markers in the sequencer - snap to grid now available on the right part of patches in the timeline - can't adjust the separator & panel module size and position in the interface builder. - bad record button update in the Dashboard. - bad width inlet update in the ramp module - better zooming in the sequencer - various display bugs in the piano roll - Various package problems in the VST version
[4.0 beta 8] fixed bugs - bad audio input affectation in the setup (when inputs are duplicated) - bad wire addition when both have a null input. - display details in the wire monitor panel - the list box inlets in User Modules aren't properly saved - endless callback loop in User Modules (when a modal window is displayed)
[4.0 beta 7] improvements - fill ramp array module - clear inlet queue data fixed bugs - some various display bugs in control panel & Module Panel.
[4.0] Touch Screen Edition see the demo videos here
more than 100 improvement: - touch screen management - 16 audio in/out - clear/save/open current track command in the main menu - new possible location for Interfaces builder windows: patch or parent patch - new rack mode : 'grid', 'rack' or 'play all' - customizable layouts for all displayed controls (set the colors you want to all controls). - reset + reset values in steps modules (step, step-midi, lines, switches, points, array) - no more auxiliary busses order limitations - expand module command in patches (see manual) - some PianoRoll improvements - clear current CC curve in PianoRoll - more quantize options in the sampler/ grainSampler :2,4,6,8,10,12,14,16 bars - New command in the main menu to hide all the popup windows (tab] key) - new mapper curve module design (shows now a cursor to display the current position) - new Audio Selector sub-patch in the module library - new Wave Display sub-patch in the module library - better record (direct to disk) engine - better multi-thread optimization - more precise Send Midi Time Clock module in the Library - new conductor module more powerful; see compatibility notes. - the color of the line in the remote panel is the same than the control color - at the startup of Usine, the last main window position is memorized - debug mode in the setup for user modules developers - more precise schedule in the mouse down outlet of the separator/panel module - the audio out is cleared when a patch activation is turned off - 'visible' inlet/outlet in the Interface Builder module - the mapper curve can process audio flow (see 'audio quality' parameter) - a sub patch can be locked to prevent modifications - the master section shows only actives in/out - new ‘default value’ parameter in faders, knobs - preview workspaces/patches info's in the the browser window - the conductor now saves all the patches of the grid in rack mode (not only the selected patch); see compatibility notes. - the 'show remote' button is visible in grid mode (not only in patch design mode) - French Quick Start
compatibility notes - the new interface control/conductor panel module is not compatible with older version. - because of the new save procedure in the conductor, you can have some small compatibility problems with older versions.
]]>BrainModularBrainModular Users Forum2008-10-25T19:45:30+01:00https://brainmodular.org/forums/app.php/feed/topic/10972008-10-25T19:45:30+01:002008-10-25T19:45:30+01:00https://brainmodular.org/forums/viewtopic.php?t=1097&p=5898#p5898Statistics: Posted by antwan — 25 Oct 2008, 20:45
]]>2008-10-25T15:49:02+01:002008-10-25T15:49:02+01:00https://brainmodular.org/forums/viewtopic.php?t=1097&p=5896#p5896[4.0 beta 13] improvements - midi & key learn allowed in patches of the sequencer!
