ArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-10-23T10:16:54+02:00 https://brainmodular.org/forums/app.php/feed/topic/1091 2008-10-23T10:16:54+02:00 2008-10-23T10:16:54+02:00 https://brainmodular.org/forums/viewtopic.php?t=1091&p=5847#p5847 <![CDATA[data outs on vst don't reflect changes via midi]]> Statistics: Posted by bsork — 23 Oct 2008, 10:16
2008-10-23T09:46:58+02:00 2008-10-23T09:46:58+02:00 https://brainmodular.org/forums/viewtopic.php?t=1091&p=5846#p5846 <![CDATA[data outs on vst don't reflect changes via midi]]>
I assume if I use midi learn, the connection from cc to fader is going to be active all the time, right?
Statistics: Posted by woodslanding — 23 Oct 2008, 09:46
2008-10-23T08:39:08+02:00 2008-10-23T08:39:08+02:00 https://brainmodular.org/forums/viewtopic.php?t=1091&p=5844#p5844 <![CDATA[data outs on vst don't reflect changes via midi]]>
I'm not sure where the fault lies with the missing update of output parameters when using CCs - Usine, VST or just a "mismatch" between the two - but here's another way of doing it the I'm pretty sure will work no matter where you change the parameters:
Connect the VST's outputs through a PassOnlyIfHasChanged to the faders, and the faders back into the VST. Use MIDI learn on the faders to assign the CCs, and there you go. You may have to remove the CCs assignments on the VST to avoid hiccups.
Statistics: Posted by bsork — 23 Oct 2008, 08:39
2008-10-23T03:24:39+02:00 2008-10-23T03:24:39+02:00 https://brainmodular.org/forums/viewtopic.php?t=1091&p=5841#p5841 <![CDATA[data outs on vst don't reflect changes via midi]]>
Unfortunately, if I change the drawbar settings via midi CCs, this is not reflected in the VSTs parameter outputs, although the drawbar positions are changing on the vst's graphic. If I drag drawbars on the vst graphic with the mouse, it DOES reflect in the parameter outs!
This actually strikes me as a bug, but maybe it's more of an unimplemented feature.
I guess to get this to work, I need a bunch of midi filters to control my faders, and cable them to the midi out--or would that even work???
Anyway, it sure would be cleaner to use the parameter outs.
cheers!
-e
Statistics: Posted by woodslanding — 23 Oct 2008, 03:24
cheers!
-e
