ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2006-06-28T09:51:06+01:00https://brainmodular.org/forums/app.php/feed/topic/1092006-06-28T09:51:06+01:002006-06-28T09:51:06+01:00https://brainmodular.org/forums/viewtopic.php?t=109&p=450#p450Most of problems come from drivers. It?s harder to make a good driver than the card itself?
The tested soundcard list, feel free to complete the list!
[best sound and drivers] RME fireface 800 RME digixxx serie RME Hammerfall HDSP Presonus Firepod & Firebox
[good sound sound and drivers] M-audio FWxxxx serie Digidesign Mbox I
[works but poor drivers] Edirol FA101 Edirol UA25
[works only with Asio4all] Realtek built in sound card
]]>2006-06-26T07:33:30+01:002006-06-26T07:33:30+01:00https://brainmodular.org/forums/viewtopic.php?t=109&p=448#p448 You'll have to enable inputs and outputs in asio4all as well as in Usine. Go to File/Setup, and in the asio section choose asio4all as the device, click the panel button to get to the asio4all setup to enable/disable in-/outputs, and then activate those in Usine (and name them if you want).
I've had no trouble using asio4all together with Usine, and for me it has worked fine both with my M-Audio Ozonic and the built-in soundcard.
A little tip: in Usine, the available in-/outputs can be placed at will. The default behaviour is of course that eg. "In 1" is the two first inputs from the driver, and "Out 2" is outputs no 3&4, etc. If you - like me - have mono sources connected, choose the same input for both L and R of the pair.
Hope this might have been of some help. Without any more technical details and/or descriptions of what you've done, it's hard to be more specific.
]]>2006-06-25T15:10:03+01:002006-06-25T15:10:03+01:00https://brainmodular.org/forums/viewtopic.php?t=109&p=447#p447Statistics: Posted by laserbeak43 — 25 Jun 2006, 16:10
2006-06-25T15:08:53+01:002006-06-25T15:08:53+01:00https://brainmodular.org/forums/viewtopic.php?t=109&p=446#p446Statistics: Posted by laserbeak43 — 25 Jun 2006, 16:08
]]>2006-06-25T06:31:25+01:002006-06-25T06:31:25+01:00https://brainmodular.org/forums/viewtopic.php?t=109&p=445#p445Statistics: Posted by fxe — 25 Jun 2006, 07:31
]]>BrainModularBrainModular Users Forum2006-06-28T09:51:06+01:00https://brainmodular.org/forums/app.php/feed/topic/1092006-06-28T09:51:06+01:002006-06-28T09:51:06+01:00https://brainmodular.org/forums/viewtopic.php?t=109&p=450#p450Most of problems come from drivers. It?s harder to make a good driver than the card itself?
]]>2006-06-25T15:08:53+01:002006-06-25T15:08:53+01:00https://brainmodular.org/forums/viewtopic.php?t=109&p=446#p446Statistics: Posted by laserbeak43 — 25 Jun 2006, 16:08
