ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2008-11-13T21:28:30+01:00https://brainmodular.org/forums/app.php/feed/topic/10822008-11-13T21:28:30+01:002008-11-13T21:28:30+01:00https://brainmodular.org/forums/viewtopic.php?t=1082&p=6247#p6247I bought the Monome from monome.org and already have it for awhile and played with MLR etc. Great! I am not so much a programmer, so Max MSP is nothing for me, but Usine is! I am wondering how the feedback between Usine and Monome will work (led's flashing etc.)
Thank you all!
Cheers!
Robbe
Statistics: Posted by Robbe K — 13 Nov 2008, 21:28
Statistics: Posted by Clearscreen — 13 Nov 2008, 04:55
]]>2008-11-13T01:29:48+01:002008-11-13T01:29:48+01:00https://brainmodular.org/forums/viewtopic.php?t=1082&p=6238#p6238Statistics: Posted by eimhin — 13 Nov 2008, 01:29
monomeserial (core software) lets u translate each monome key to a midi note. plus, there is a second midi channel for input to control LEDs flashing. in usine it is easy to have eg. a stepsequencer and receive+generate midi events for every step (each step has in-/outlets).
can't you directly communicate with OSC though?
Statistics: Posted by Clearscreen — 13 Nov 2008, 00:44
]]>2008-11-13T00:34:36+01:002008-11-13T00:34:36+01:00https://brainmodular.org/forums/viewtopic.php?t=1082&p=6234#p6234 congrats you managed to grab a monome. when did you buy it (from monome.org)?
about how to use it. monomeserial (core software) lets u translate each monome key to a midi note. plus, there is a second midi channel for input to control LEDs flashing. in usine it is easy to have eg. a stepsequencer and receive+generate midi events for every step (each step has in-/outlets).
naturally you could also use one of the ass kicking maxMSP projects or VSTi plugins for monome and add more functionality with usine
Statistics: Posted by amiga909 — 13 Nov 2008, 00:34
]]>2008-11-13T00:12:42+01:002008-11-13T00:12:42+01:00https://brainmodular.org/forums/viewtopic.php?t=1082&p=6233#p6233Could you help me with this? Do you have an example I could play with?
Thank you in advance!
Robbert
Statistics: Posted by Robbe K — 13 Nov 2008, 00:12
]]>2008-10-21T23:43:29+01:002008-10-21T23:43:29+01:00https://brainmodular.org/forums/viewtopic.php?t=1082&p=5813#p5813Statistics: Posted by Clearscreen — 22 Oct 2008, 00:43
]]>2008-10-21T21:17:29+01:002008-10-21T21:17:29+01:00https://brainmodular.org/forums/viewtopic.php?t=1082&p=5812#p5812Statistics: Posted by eimhin — 21 Oct 2008, 22:17
]]>2008-10-21T07:32:01+01:002008-10-21T07:32:01+01:00https://brainmodular.org/forums/viewtopic.php?t=1082&p=5787#p5787
looking at monome's OSC protocol's shouldn't it be more like: /40h/press [x] [y] [state] to receive OSC, and something like: /40h/led [x] [y] [state] to send to the monome
again, i could be wrong but i thought this might help
Statistics: Posted by Clearscreen — 21 Oct 2008, 08:32
]]>2008-10-21T05:58:00+01:002008-10-21T05:58:00+01:00https://brainmodular.org/forums/viewtopic.php?t=1082&p=5785#p5785 I've got OSC active, and when I have "monitor localhost" checked, the OSC indicator will light up when I press buttons on my monome. So I figure this means I am successful. The only problem is I cannot get the OSC send and receive modules to communicate with it.
In addr I have "/usine/press 0 0 1"
so [x] [y] [0 or 1]
for which pad on the monome, and then off or on.
When I press the pads, the OSC indicator lights up, but the module receive light doesn't light up.
The monome uses an app called MonomeSerial to communicate OSC. For apps to communicate, it has to be at the localhost addess 127.0.0.1
]]>BrainModularBrainModular Users Forum2008-11-13T21:28:30+01:00https://brainmodular.org/forums/app.php/feed/topic/10822008-11-13T21:28:30+01:002008-11-13T21:28:30+01:00https://brainmodular.org/forums/viewtopic.php?t=1082&p=6247#p6247I bought the Monome from monome.org and already have it for awhile and played with MLR etc. Great! I am not so much a programmer, so Max MSP is nothing for me, but Usine is! I am wondering how the feedback between Usine and Monome will work (led's flashing etc.)
Thank you all!
Cheers!
Robbe
]]>2008-11-13T00:44:14+01:002008-11-13T00:44:14+01:00https://brainmodular.org/forums/viewtopic.php?t=1082&p=6235#p6235
Robbert
so [x] [y] [0 or 1]
