I have just tested the patch and it is really awesome!!!! The features inside are so brillantly organised, it's a so cool tool for beats loops and at the same time can be very smooth now for soundscape and with the possibility of choosing which files are in group, it will allow me to have semi random approach with long files.So it will bring a lot of nice musical surprises because my plan is to use 4 Samplers list grouped at the same time
thanks a lot
Statistics: Posted by noise2sine — 21 Oct 2008, 09:54
]]>2008-10-21T08:28:32+01:002008-10-21T08:28:32+01:00https://brainmodular.org/forums/viewtopic.php?t=1071&p=5794#p5794Statistics: Posted by bsork — 21 Oct 2008, 09:28
2008-10-21T07:55:15+01:002008-10-21T07:55:15+01:00https://brainmodular.org/forums/viewtopic.php?t=1071&p=5789#p5789 Thank u so much Bsork!!!!
Statistics: Posted by noise2sine — 21 Oct 2008, 08:55
]]>2008-10-20T22:48:25+01:002008-10-20T22:48:25+01:00https://brainmodular.org/forums/viewtopic.php?t=1071&p=5782#p5782Statistics: Posted by ethnix73 — 20 Oct 2008, 23:48
]]>2008-10-20T22:11:59+01:002008-10-20T22:11:59+01:00https://brainmodular.org/forums/viewtopic.php?t=1071&p=5780#p5780 This has become more complex than I imagined when I started patching...
Statistics: Posted by noise2sine — 20 Oct 2008, 15:32
]]>2008-10-20T13:32:57+01:002008-10-20T13:32:57+01:00https://brainmodular.org/forums/viewtopic.php?t=1071&p=5762#p5762Statistics: Posted by bsork — 20 Oct 2008, 14:32
]]>2008-10-20T10:37:19+01:002008-10-20T10:37:19+01:00https://brainmodular.org/forums/viewtopic.php?t=1071&p=5754#p5754 I have played with it for quite a long time, i really enjoyed that!!!! As i mention before, i can't find a way of playing long file ??? even when i'm selecting just 1 step, at the end of the sample it just stops and it supposed to go to the next sample within the group chosen according the reading mode ???
Statistics: Posted by noise2sine — 20 Oct 2008, 11:37
]]>2008-10-17T23:03:34+01:002008-10-17T23:03:34+01:00https://brainmodular.org/forums/viewtopic.php?t=1071&p=5729#p5729Statistics: Posted by bsork — 18 Oct 2008, 00:03
]]>2008-10-17T11:04:04+01:002008-10-17T11:04:04+01:00https://brainmodular.org/forums/viewtopic.php?t=1071&p=5728#p5728 I hadn't actually thought of this patch as a "groove maker" before I created it, but I've found that with rhythmical loops and the gate length set to "to next trigger" with various lengths between the triggers, the result can be quite cool as shorter or longer portions of the sample(s) are being played.
]]>2008-10-17T06:25:06+01:002008-10-17T06:25:06+01:00https://brainmodular.org/forums/viewtopic.php?t=1071&p=5721#p5721noise2sine , thanks to share your ideas , and bsork....you're the math/logic boss !!!
Statistics: Posted by nay-seven — 17 Oct 2008, 07:25
]]>2008-10-17T00:35:41+01:002008-10-17T00:35:41+01:00https://brainmodular.org/forums/viewtopic.php?t=1071&p=5719#p5719 As requested by Noise2sine in http://www.sensomusic.com/forums/viewtopic.php?id=1048(I hope), with a couple of extras.
thanks a lot
]]>2008-10-21T07:55:15+01:002008-10-21T07:55:15+01:00https://brainmodular.org/forums/viewtopic.php?t=1071&p=5789#p5789 Thank u so much Bsork!!!!
