ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-10-29T06:48:19+01:00 https://brainmodular.org/forums/app.php/feed/topic/1066 2008-10-29T06:48:19+01:00 2008-10-29T06:48:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=1066&p=5977#p5977 <![CDATA[Shortcut for conductor lite view?]]>
I built a similar component the first day I had usine (minus the 7 presets--but with a fader to control preset number instead--and a text display) and it is very nice. But I wanted a better way to select presets by name.
It will do for now. But I hope the new touchscreen combobox behaviour will also work with the conductor. When I'm improvising, I like to see a lot of patch options laid out for me--I don't always know in advance what sounds I'll want to use!
well, I'll work something out. I'm sure there are options I haven't considered.
Statistics: Posted by woodslanding — 29 Oct 2008, 06:48
2008-10-28T20:33:36+01:00 2008-10-28T20:33:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=1066&p=5964#p5964 <![CDATA[Shortcut for conductor lite view?]]> but you can take a look on the Big Conductor example in the Touch Screen Library.
I'm sure it rocks for you!
Statistics: Posted by senso — 28 Oct 2008, 20:33
2008-10-28T19:38:22+01:00 2008-10-28T19:38:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=1066&p=5962#p5962 <![CDATA[Shortcut for conductor lite view?]]>
I note that the 'show' input on the conductor object always shows the conductor, not the conductor lite, regardless of which window was enabled.
Seems like workspaces that contain a conductor object always start up with conductor lite window open.
I wish I could resize the conductor lite window. I don't need so much width, and those little buttons up top are too small for a touchscreen.
Better yet would be a conductor object that could appear as a regular list in the touchscreen window.... a floating window is not helpful in a touchscreen environment.
But I think if I can always get the conductor lite window to appear and disappear with an external midi control, that will work okay.
cheers,
-eric
Statistics: Posted by woodslanding — 28 Oct 2008, 19:38
2008-10-23T14:54:43+01:00 2008-10-23T14:54:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=1066&p=5862#p5862 <![CDATA[Shortcut for conductor lite view?]]> It works fine, thanks!
Statistics: Posted by La Tenaille — 23 Oct 2008, 15:54
2008-10-17T09:14:18+01:00 2008-10-17T09:14:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1066&p=5725#p5725 <![CDATA[Shortcut for conductor lite view?]]>
Statistics: Posted by La Tenaille — 17 Oct 2008, 10:14
2008-10-16T21:23:02+01:00 2008-10-16T21:23:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=1066&p=5714#p5714 <![CDATA[Shortcut for conductor lite view?]]> So you will be able to create any key affection to show the window.
Statistics: Posted by senso — 16 Oct 2008, 22:23
2008-10-16T10:54:25+01:00 2008-10-16T10:54:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=1066&p=5701#p5701 <![CDATA[Shortcut for conductor lite view?]]> Possible?
CTRL+F7 shows the normal view only... Or perhaps a way to remember the last window status (normal or lite)?
Statistics: Posted by La Tenaille — 16 Oct 2008, 11:54
cheers,
-eric
