2006-06-23T05:02:49+01:002006-06-23T05:02:49+01:00https://brainmodular.org/forums/viewtopic.php?t=106&p=443#p443Statistics: Posted by laserbeak43 — 23 Jun 2006, 06:02
]]>2006-06-22T00:24:41+01:002006-06-22T00:24:41+01:00https://brainmodular.org/forums/viewtopic.php?t=106&p=437#p437Just to add that Usine runs also perfectly on my Macbook with windows Xp intalled! Keep doing this great work, and thanx a lot senso! Regards,
B.
Statistics: Posted by bmoussay — 22 Jun 2006, 01:24
]]>2006-06-21T19:03:54+01:002006-06-21T19:03:54+01:00https://brainmodular.org/forums/viewtopic.php?t=106&p=434#p434More like in pro-tools than audiomulch. The main conceptual problem is to communicate between the time line and patch's. I'm thinking about...
]]>2006-06-20T22:45:56+01:002006-06-20T22:45:56+01:00https://brainmodular.org/forums/viewtopic.php?t=106&p=431#p431Just to say I deeply admire your work. Your software is one of the most amazing ones I've ever worked with. It is a very very clever concept. I'm just starting to explore it. I'm just in the beggining... Thanks.
Rods
Statistics: Posted by Guest — 20 Jun 2006, 23:45
]]>2006-06-20T19:44:23+01:002006-06-20T19:44:23+01:00https://brainmodular.org/forums/viewtopic.php?t=106&p=430#p430-Usine work?s fine on Mac/Intel book pro - Win XP installed. -200 registered members on the forum, but don?t worry, I?m still a musician! -I?m working on a major update, with a ?sequencer timeline?. Almost like in ?Cubase?, but with patch?s instead of the traditional waves files. It seems artistically very promising. A beta version will be available for download soon.
]]>BrainModularBrainModular Users Forum2006-07-12T14:21:02+01:00https://brainmodular.org/forums/app.php/feed/topic/1062006-07-12T14:21:02+01:002006-07-12T14:21:02+01:00https://brainmodular.org/forums/viewtopic.php?t=106&p=484#p484Statistics: Posted by BoksteR — 12 Jul 2006, 15:21
]]>2006-06-23T05:02:49+01:002006-06-23T05:02:49+01:00https://brainmodular.org/forums/viewtopic.php?t=106&p=443#p443Statistics: Posted by laserbeak43 — 23 Jun 2006, 06:02
B.
Rods
